front axle for mag wheels are they the same on all
- odl666
29 Apr 2008 17:27
are all the front wheel axles the same for all mag wheels i am in need of one soon to finish my project. thanks if any one finds one on ebay for cheap let me know i ve already looked but didnt know which ones would work. thanks
1978 kz 650b with gpz faq mods cams carbs polished and ported
1979 gs750e
1972 bsa lightning under construction
1979 gs750e
- steell
Re: front axle for mag wheels are they the same on all
29 Apr 2008 20:04
Nope, and it depends on year/models.
Tell us the year and model of the front forks (77 KZ1000 80 KZ650, etc), and we can probably tell you what fits.
- odl666
29 Apr 2008 23:37 - 29 Apr 2008 23:42
The forks that are on my bike are off a kz 650 b 4 cylinder 1978. The wheel i am not sure what it is off of. I was planning on using the 650's old front axle it was a spoked rim. I also think the mag front wheek i have may be off a early 80's 550 maybe?
1979 gs750e
1979 gs750e
Last edit: 29 Apr 2008 23:42 by odl666.
- steell
30 Apr 2008 04:52
I just took two 650 front mag wheels to the scrapyard
78 KZ650/750 twin/1000 all have the same diameter front axle, 80's KZ550 probably has a smaller axle.
Use a dial/digital/vernier caliper to measure the ID of the forks (where the axle goes) and the ID of the wheel bearings in the wheel, if they are the same size, then it's simply a matter of spacers (and maybe moving the caliper or rotor to line them up).
- odl666
30 Apr 2008 11:16
do you think maybe just changing out the bearings ones that have a larger ID and a smaller OD. thanks for the help!
1979 gs750e
1979 gs750e
