The Pingel Motor Mount Kit
- Samwell
29 Apr 2008 02:27
Well, the nice man from the post office finally brought it. AS a backgrounder, I've been looking for a heavy duty motor mount kit for my 1978 kz1000 project.
I found one at Pingel online. It appears quite similar to the kosman kit. all of the plates are much thicker, and the spacers on the rear mount are therefore shorter.
With the exception of the two bolts on the right lower engine mount (the two that screw into the frame), all of the bolts are larger and most of the mounting holes have to be drilled out slightly to accomodate them. This is by no means onerous.
The only downside so far is the rear mount plates don't come the brackets attached to hold the rear brake light switch on the right and the battery box on the right. Minor quibbles, when I figure it out I'll add it to this post.
On the whole this seems like a nice upgrade to the chassis. WHen the bike is running, I'll post more of this review.
Sam
Sam
- bill_wilcox100
Re: The Pingel Motor Mount Kit
29 Apr 2008 04:58
Good stuff Sam. Any chance of getting of pic of what came out of the box... kind of interested in this.
Best of success.
Best of success.
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Upgrades:
Montreal, Canada
- StreetfighterKz
29 Apr 2008 08:39
Samwell wrote:
What's the thickness of the plates? I assume 3/8" or so?
Post pics when you get done!
Later, Doug
All of the plates are much thicker, and the spacers on the rear mount are therefore shorter.Sam
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- StreetfighterKz
29 Apr 2008 08:45
1979 z650 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- PLUMMEN
29 Apr 2008 09:14
purdy,stainless bolts?
- bill_wilcox100
29 Apr 2008 13:14
Good stuff!
Now that I see the before, I'm really looking forward to the after pic.
Thanks. Best of success!
Upgrades:
Montreal, Canada
Upgrades:
Montreal, Canada
- Samwell
29 Apr 2008 14:29
bill_wilcox100 wrote:
Its probably a bit late but here's my picture.
I'm headed out of town for a few days, I'm hoping to have the motor back in the frame next week...Then its degreeing cams!
Sam
Best of success.
Sam
- roystaylor
- StreetfighterKz
02 May 2008 11:47
I think when I got onto the site to find a pic the motor mount kit was $175.
I'm planning on buying some 6061-T6 plate and making my own using the stock mounts as templates. I have access to a mill, lathe, etc. so it shouldn't be all that difficult. Just have to source the hardware.
Later, Doug
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- wiredgeorge
02 May 2008 11:52
Unless you want to use ALL-THREAD for the longer bolt, I think Jeff at Z1E can get the long 10mm bolt from PMC in Japan made out of stainless... I have heard about a socket head and hex head version... not sure but you could check with him.
- Samwell
12 May 2008 18:05
Here's what it looks like with an engine in the frame again.
The cases have been bead blasted and the cylinders sprayed black. Once I get around to it I'll bolt the head on and actually try to start it. Things fit pretty well. I had to struggle with only one bolt. The rest slid into place once I bored out the holes to the proper size.
Sam
Good stuff!
Sam
- bill_wilcox100
12 May 2008 22:04 - 12 May 2008 22:08
Hey Sam, now that engine looks real good. Well done.
Did you do the blasting yourself? If not, about how much $ did it set you back? :dry:
Best of success!
Best of success!
Upgrades:
Montreal, Canada
Upgrades:
Montreal, Canada
Last edit: 12 May 2008 22:08 by bill_wilcox100.
