tire and rim width suggestions
  • Kawiman80
  • Kawiman80's Avatar Topic Author
  • On my 2nd KZ1000
25 Apr 2008 10:04
#209010
I have purchased a 6" over swing arm off of ebay and need some recomendations on rim and tire sizes. The width is 9" at the axle adjusters. I would like to use a sportbike rim if neccessary but I do have an 18x3.5 rim that can be laced to a hub that I have. Any suggestions would be greatly appreciated,plus any info on any other mods to make it fit also greatly appreciated.:S
Thanks Mike
1980 kz1000g 1105 34mm Mikuni flat slides Kerker exhaust custom paint stock ignition(Dyna 2000 soon) Accel coils and wires stock cams w/ heavy springs for more rpm. My 2nd 1000.
  • 79MKII
  • 79MKII's Avatar
  • Love Them Kaws!
Re: tire and rim width suggestions
25 Apr 2008 10:42 - 25 Apr 2008 10:43
#209020
I'm guessing that 4" is probably about as wide as you can go without making some mods. I have used a 3.5" with no problems. I have a 6" on mine now and it was a real pain to make it work. Keep us posted on the progress. By the way, is your '80 and LTD model? Nevermind, just noticed the "G" in your signature. Does your EFI still work on that Classic?
The Kaw List:
Last edit: 25 Apr 2008 10:43 by 79MKII.
  • Kawiman80
  • On my 2nd KZ1000
25 Apr 2008 13:49
#209068
NO THE EFI WAS REPLACED WITH 36 MM MIKUNIS WHEN I PURCHASED THE BIKE. IJUST FINISHED REPAINTING IT AND CLEANING IT UP A BIT. I DON'T HAVE MUCH TIME TO REALLY TEAR INTO IT FOR A COMPLETE RESTO ON IT RIGHT NOW I SHOULD HAVE MORE TIME IN THE NEXT COUPLE OF YEARS. I POST PICS SOON. I HOPE YOU GUYS APPROVE.
THANKS FOR THE INFO.
  • PLUMMEN
  • PLUMMEN's Avatar
25 Apr 2008 20:38
#209145
measure about 10" forward of the axle mounting area,that is about where your tire will be riding which is your max width;)
  • Kawiman80
  • On my 2nd KZ1000
26 Apr 2008 12:01
#209263
Hey Thanks. I will do that and get back with you guys!:cheer:
  • Kawiman80
  • On my 2nd KZ1000
28 Apr 2008 06:51
#209729
Hey Plummen, The width 10" forward is 7.5" wide. Not much room for a sport bike rim? But I have a 3.5" aluminum spoke rim> would a 150 series rubber fit? What ratio would you recommend? it's 18" dia.
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
28 Apr 2008 08:35
#209759
how do u like the rs36's ? do u have a bog in the lower rpm's?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • Kawiman80
  • On my 2nd KZ1000
28 Apr 2008 09:23
#209775
yes mark i do have a bog in the lower rpm but it is not bad. i need to change the pilot jet from a 17.5 to a 15 and it should take care of the problem.
  • PLUMMEN
  • PLUMMEN's Avatar
28 Apr 2008 13:00
#209818
id say something in the neighborhood of a 150/70 18 would work out pretty good on there;)
  • 79MKII
  • 79MKII's Avatar
  • Love Them Kaws!
28 Apr 2008 14:34 - 28 Apr 2008 14:36
#209839
I think I had a 150 (or maybe a 160?) on my 3.5" rim. That was with the stock 630 chain and sprocket set up. I think the first problem you're going to run into is the chain hitting the tire. 7.5" inside the swingarm is pretty wide. 7.5" = 190mm, so you could probably squeeze a 170 or 180 on there, but again, you'd have to offset your chain and would need a wider wheel too. I think the widest tire recommended for a 3.5" rim is the 150mm. I think wireman is right on with that suggestion. ;)
Now how about some pictures??:P :)
The Kaw List:
Last edit: 28 Apr 2008 14:36 by 79MKII.
  • Kawiman80
  • On my 2nd KZ1000
20 May 2008 07:33
#214719
THIS IS AN UPDATE TO THIS TOPIC. i HAVE YET TO INSTALL THE SWING ARM BECAUSE IT'S RIDING SEASON!!!!!!!!!! I PLAN ON IT OVER THE WINTER HERE IN THE MIDWEST THOUGH. IT IS NOW PAINTED AND ON THE ROAD!!!!:cheer: :cheer: I WENT TO BIKE AND CAR SHOW OVERR THE WEEKEND,AND I WAS DISAPPIONTED! I DIDN'T SEE A KZ IN THE SHOW AT ALL!!!! I GUESS THE GUYS THAT OWN THEM AROUND HERE DON'T LIKE SHOWING THEM OFF? I PLAN ON SHOWING MINE NEXT YEAR!!!! THE SHOW GAVE THE PUSH I NEEDED TO GET THIS THING DONE AND GETTING THE RESPECT THESE BIKES DESERVE WHEN COMPETING AGAINST A BUNCH OF HARLEY'S!!!!!! OH BUY THE WAY HERE IS SOME PICS!!!! I HOPE YOU LIKE THEM.THEY ARE IN THE GALLERY ALSO.
  • inline4
  • inline4's Avatar
21 May 2008 21:13
#215021
Love the paint job. Very Nice.B)
Please don't use all CAPS when posting; it's like you are screaming at us.:)
