warped disks
- mark1122
- Keep twisting it
warped disks
20 Apr 2008 07:54 - 20 Apr 2008 08:03
Can warped disks be straitened in a press or? I bought a 96zx9 front end for my 76 kz and just discovered the disks are out 2.2 mm.So this means the disk will push the pads back about 1.1 mm on each side of the disk.i dont have a spec for the zx9 but the kz manual says 1mm. total is too much.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 20 Apr 2008 08:03 by mark1122.
- Bluemeanie
Re: warped disks
20 Apr 2008 09:39 - 20 Apr 2008 09:40
No, you do not want to bend a dic back into shape!! Is the rotor just warped or is it bent (accident?) at the mounting flang? It needs to be machined flat but then of course you will be removing much valuable metal. Sounds like time for a replacement... sorry
Last edit: 20 Apr 2008 09:40 by Bluemeanie.
- mark1122
- Keep twisting it
Re: warped disks
20 Apr 2008 11:13
id say they are warped.Heat?both sides are about the same?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- bountyhunter
Re: warped disks
20 Apr 2008 13:54
mark1122 wrote:
A warped disc must be turned on a lathe to re true. I was lucky enough to find a couple of good used rototrs for mine on ebay for about $15 each. Turning them costs more than that.id say they are warped.Heat?both sides are about the same?
- PLUMMEN
Re: warped disks
20 Apr 2008 21:08
id say your life is much more valuable than saving a few bucks and stress cracking a brake rotor;)
- BSKZ650
Re: warped disks
21 Apr 2008 05:29
PLUMMEN wrote:
I totaly agree,, brakes are the last thing you want to screw with,, do them right
77 ltd1000, current rider
76 kz900, just waiting
- bountyhunter
Re: warped disks
21 Apr 2008 13:51 - 21 Apr 2008 13:53
mark1122 wrote:
If your rotor really is warped 2.2mm (.090" ) total, it's junk. No way you could cut enough steel off the faces to get them true again and still have enough left to run. That is a seriously warped rotor.
I'm surprised that the manual says rotor warp of 1 mm (which is .040" ) is allowable. That's WAYYYY more than I would think is allowable. I would have thought it would be more like about 1/10 of that, but that's just a guess based on car rotors.Can warped disks be straitened in a press or? I bought a 96zx9 front end for my 76 kz and just discovered the disks are out 2.2 mm.So this means the disk will push the pads back about 1.1 mm on each side of the disk.i dont have a spec for the zx9 but the kz manual says 1mm. total is too much.
Last edit: 21 Apr 2008 13:53 by bountyhunter.
