Help Identify Mystery Parts?
- skippr76KZ
31 Jan 2006 16:27
:blink: It was bound to happen. Things I took off the old KZ900LTD last year, all of a sudden don't look to familiar to me when it's time to replace or put them back on. Can anybody help me identify these rubber plug type things with a metal sleeve insert? Pretty sure it's not turn signal parts (no diamond shape) but I can't be for sure. In the meantime I'll continue to peruse the parts diagram. These things look pretty worn. Thanks.
1976 KZ900LTD Fully Restored
2000 Vulcan FI Classic
1998 Ducati ST2, Gone
- bob_z1
Re: Help Identify Mystery Parts?
31 Jan 2006 16:34
is there a hole thru them? look like the rear exhaust hanger bushings.....
- roy-b-boy-b
31 Jan 2006 16:53
I'm a thinking that they are the rubber pieces that holds the back cowl on. Two on top and two underneith.Roy
Post edited by: roy-b-boy-b, at: 2006/01/31 19:53
- 77KZ650
31 Jan 2006 18:01
I have no idea, but this might help the pros out there, try putting a ruler beside them and take the pic again. hope this might help, good luck.
Scott
Scott
07 MDP Rookie of the Year
- skippr76KZ
31 Jan 2006 18:37
I thought too late to put the ruler next to them. I've re-done the photo. The ruler is 6 inches across. I'm thinking the back cowl thing sounds like it might be it. I'll check the parts diagram.
- BSKZ650
31 Jan 2006 18:53
I am not sure but they kind fo look like rear fender mount rubbers, missing the tops and bolts
77 ltd1000, current rider
76 kz900, just waiting
- Jeff.Saunders
31 Jan 2006 19:34
Exhaust mount dampers from the rear lower mount point - 1 from either side of the mount point on each side of the frame.
www.z1enterprises.com
Z1 Ent on Facebook,
- roy-b-boy-b
01 Feb 2006 02:11
I haven't seen one of those in years! Roy
- skippr76KZ
01 Feb 2006 05:58
Thank you Jeff! Next question might be, do they look useable in that role. Not sure these things are that readily available. Thanks for the help guys.
- wireman
01 Feb 2006 06:14
i wonder if Z1 sells them,check wesite:whistle:
- roy-b-boy-b
01 Feb 2006 10:55
If you see the price of new one you will see thos used one in a diffrent light. Roy :ohmy:
- skippr76KZ
01 Feb 2006 13:32
Good observation, Roy-b-boy-b. Some soap and water, a tooth brush, metal brush and some aerospace 303 protectant may be in order. Didn't see it on Z1's site wireman - but I'll double check. I about have the kz900 section memorized with all the visits looking for stuff I'm going to have to replace. :pinch:
skipsteiger.home.mchsi.com/before/
