How to rebuild the master cylinder
- 1975KZ400D
19 Apr 2008 06:56
I need to rebuild the master cylinder on my 75 KZ400D. Could anyone give me a link to instructions on how to do this, or a diagram that shows how to do this? I appreciate the help!! :woohoo:
- ThatGPzGuy
Re: How to rebuild the master cylinder
19 Apr 2008 08:50
Your manual should have a description. Basically you pull out the old and replace with new. Check to make sure the bore is clean and free of rust. If it is rusty you will probably have to replace it. Keep everything clean. Bleed it real good and go out and ride it.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
- tool maker
29 Apr 2008 17:54
You can pick up a rebuild kit for about 30 bucks at Z1 Enterprises, If the bore isn't perfect you can just hone it out. Good luck.
Lancaster, PA
82 KZ1000 M2, stage 3 jet kit, pods, 4 into 1 Mac, Accel coils & wires.
- Jeff.Saunders
29 Apr 2008 18:16 - 29 Apr 2008 18:19
at the bottom of the reservoir cup are two holes. One is obvious and easy to clean, the other is smaller than a pin hole and MUST be clear for you to be able to bleed the brakes effectively. A single strand from a fine wire brush, or carb cleaning spikes will clear the hole. The Kawasaki parts diagrams on Kawasaki.com (under owner info) will help with an exploded view of the parts as it shows the sequence and orientation of the parts.
Last edit: 29 Apr 2008 18:19 by Jeff.Saunders.
