Changing rear wheel bearings.
  • Oldwolf
  • Oldwolf's Avatar Topic Author
18 Apr 2008 16:29
#207453
Changing rear wheel Bearings on a 77 KZ1000. The Manual says to tap them out then press them in. Do you Press them in by hand? Swing Arm bearings tap out and then press in with what kind of press.
1977 KZ1000A1, 1105cc,Mikuni RS34mm FS, K&N Pods,Kerker 4/1,Dyna S Ign,Coils & Plug Wires,Progressive Sup. Front&Rear, Derale Oil Cooler.
  • bountyhunter
  • bountyhunter's Avatar
Re: Changing rear wheel bearings.
18 Apr 2008 16:48
#207454
I don't think they can be pressed in by hand. I thought you could use a round tool to drive them in? haven't done bearings in a long time, in cars they use a hydraulic press.
  • PLUMMEN
  • PLUMMEN's Avatar
18 Apr 2008 17:52
#207462
wheel bearings:remove snap rings get yourself a piece of brass rod and a hammer,tap tap tap.it might help to toss the bearing in the freezer wrapped in something for 20-30 minutes.from what i remember bearings are same 900-1000;)
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
19 Apr 2008 02:20
#207521
Just did wheel bearings (front and rear) over the past several days on my KZ750R1...cumulative time for doing the bearings (wheels off the bike), e.g. bearing removal and installation, was about 15 minutes. For me the key is having the correct tools...this meant that I had both a tool for bearing removal (search eBay for a motorcycle bearing tool) and a bearing driver set. I have maybe $60.00 in both these tools, but I have five bikes to maintain. You will be able to fabricate tools to drive bearings (a socket the same diameter as the bearing might do) but the bearing removal tool was a joy to use...there are several threads on this site on what I'm typing about:)
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • inline4
  • inline4's Avatar
19 Apr 2008 05:41
#207537
For the easiest bearing removal look into getting this priceless tool from PitPosse. One of my favorite tool investments.B)
www.pitposse.com/whbereset.html
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
19 Apr 2008 06:35
#207545
yep...that's the one:)
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
