Chain length for 630/530 swap
  • kneedragger80
  • kneedragger80's Avatar Topic Author
14 Apr 2008 06:33
#206324
I want to change from a 630 to a 530 chain on my 750E.
Current ratio: 33/13 = 2.54
New ratio: 40/16 = 2.5
Chain: 84 link = 100 link
I have 2 questions:
1) Do I have to increase the link count on the new chain to account for the increased number of teeth on the new sprockets?
2) I'm assuming I'll have to shim out the front sprocket, is there an off the shelf spacer available for this?
Thanks
80 KZ750E
84 GPZ1100
NY US
. . . I used to do a little but a little wouldn t do it so a little got more and more . . .
  • mariozappa
  • mariozappa's Avatar
Re: Chain length for 630/530 swap
14 Apr 2008 06:55 - 14 Apr 2008 06:56
#206331
To be safe, you can order 102 link chain from Z1E for about the same price as 100 links and cut off what you don't need.
The 102 link 530 chain is what I use on my 650's
front sporcket shim
1977 KZ650C1
and the KZ650/KZ750 Conversion ;)
Last edit: 14 Apr 2008 06:56 by mariozappa.
  • BSKZ650
  • BSKZ650's Avatar
14 Apr 2008 09:20
#206362
if you go to z1e they have a section that tells you what chain/sprockets to use for the conversion. I did it on the 1000, I wasnt comfortable with myself, so I called and spoke to Rob...Got it right.
Note: if you go with the "o" ring chain, buy the install tool!!!!, worth the money
77 ltd1000, current rider
76 kz900, just waiting
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
14 Apr 2008 11:20
#206409
why do u think u have to shim the front sprocket? the chains should be the same thickness.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • kneedragger80
14 Apr 2008 12:11
#206430
I've searched the forums and the Z1E website for info and just wanted more info from members before I call. For some reason I just assumed I'd have to shim the front sprocket, mistakenly I guess.
Thanks to all.
80 KZ750E
84 GPZ1100
NY US
  • BSKZ650
  • BSKZ650's Avatar
14 Apr 2008 13:01
#206441
when you talk to rob, he will tell you some you do and some you dont, I bought two shims and only needed one,, .75 cents cheap just incase in my book,.
Best advice, call and talk to them,, and get the chain install tool,,, busted fingers are not fun
