Problems hooking up my speedometer cable
  • XL777
  • XL777's Avatar Topic Author
13 Apr 2008 11:22
#206128
I seem to be having an issue getting my speedometer cable to seat, and thread on to the assembly that is attached to the front wheel. It came off fine but now it wont go inside. Also when I try to thread it on it seems like the threads are smaller then the threaded cover on the cable. Any suggestions?
2012 Triumph Bonneville SE black
1978 KZ1000 B2 LTD
Fresh top end rebuild
Rebuilt head
Wiseco 1015 pistons
Dyna s
Green Dyna coils
Wired george mod
It is easier to say what I haven't replaced then what I have.
I must love this cruel mistress since she hates me
  • XL777
Re: Problems hooking up my speedometer cable
13 Apr 2008 11:31
#206130
Jeez that made no sense :) I meant that I can't get the cable nut to thread over the speedo bushing, somehow the cable nut seems larger now, and no it does not look stripped. The tounge that comes out of the cable is that supposed to hook into something. Because all I can see is a bit of metal it rests against in the busing
1978 KZ1000 B2 LTD
Rebuilt head
Wiseco 1015 pistons
Dyna s
Green Dyna coils
Wired george mod
  • rdgrnr
  • rdgrnr's Avatar
13 Apr 2008 12:01
#206136
It sounds to me that you have the cable reversed. The end with the slot in the cable, goes into your speedo drive on the front axle. Slide the cable into the drive and turn the inside cable slightly while gently pushing to get the cable to seat.The end that is square goes into the speedo itself. The end nuts are 2 different sizes...
If you have trouble at the speedo end, just roll the bike ahead slightly and it will go in...
77 KZ650B1
80 440 LTD Sold
78 GL1000 Naked Wing Sold
80 CM400E Sold
Brainerd, MN
  • XL777
13 Apr 2008 12:05
#206138
what do you know I win the dumba ass off the weekend award thanks for your help
1978 KZ1000 B2 LTD
Rebuilt head
Wiseco 1015 pistons
Dyna s
Green Dyna coils
Wired george mod
  • rdgrnr
  • rdgrnr's Avatar
13 Apr 2008 12:08 - 13 Apr 2008 12:26
#206139
You're not the first, and not the last.
I've had some of those too (more than I will admit to anyone here!!!):laugh:
777, check your PM's
77 KZ650B1
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
Last edit: 13 Apr 2008 12:26 by rdgrnr.
