csr 1981 front wheel what dia?
- School Teacher
07 Apr 2008 19:19
whats the dia?
if its aluminium is it stock(spoked)
will it work with on a 76 z900
thanks in advance
thanks in advance
1976 kz900 in parts but will be going some day soon
1980 kz1000G1
1976 kz900 parts bike
1979 kz1000 shaftie parts bike
1978 kz1000 33mm smoothies 1075 kit
Troutdale Oregon USA
1980 kz1000G1
- Chopperdaddy
Re: csr 1981 front wheel what dia?
07 Apr 2008 21:06
the diameter of the front is 19 " and the aluminum rims are factory for the csr . . . i just bought a 19 ft dual disk complete wheel with tire and 16 disc rear for my 80 ltd the wheel is going to work just fine but the bearing diameter is smaller on the csr wheel . . . i figure that the mag wheel bearings that were on my bike should work in the spokes i will see and advise or someone may chime in before then ??? If not i still think it will be easier to change the bearings to fit the larger diameter axle than to make a shim of some sort to take up the difference ???? we will see !!!!
Into all things fast. . . Drag boats, bikes and cars . .. sucker for 50\'s thru 70\'s style also
- steell
08 Apr 2008 04:54
All the answers to your bearing and fitment questions are in the Filebase under the KZ Information tab at the top of the page.
There is a wheel bearing chart that gives you the bearing numbers for each model, then you look up that bearing number and it will tell you the OD and ID of the bearing. The ID is the axle size, the OD is the size of the recess in the wheel that the bearing fits into.
Swapping wheels is not usually simple, been there, done that, learned an awful lot about standard bearing sizes
