Question on Vetter fairing
  • coppertales
  • coppertales's Avatar Topic Author
07 Apr 2008 10:48
#204793
I can't figure this one out. How do you change the bulb in the headlight in a Vetter fairing? You can't get at it from the back side. The unit must detach from the front somehow....thanks...chris3
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
  • The Gringo
  • The Gringo's Avatar
  • ¡Usted no necesita otra motocicleta!
Re: Question on Vetter fairing
07 Apr 2008 11:34
#204799
If memory serves me correctly most of the Vetter fairings used the stock headlight from the bike. When you got a Vetter kit it also came with a little vinyl or rubber cover that stretched over the remaining HL bucket to keep all the wiring shielded. Try looking at the HL rim at about 5 and 7 o'clock and see if there aren't 2 phillips head screws. If so remove them and the HL should come out.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
  • mariozappa
  • mariozappa's Avatar
07 Apr 2008 11:49
#204803
There should be a small gap in the headlight ring on the bottom. I believe you have to push that in an the ring twists right off......
Now I'm gonna have to go look...
1977 KZ650C1
and the KZ650/KZ750 Conversion ;)
  • mariozappa
07 Apr 2008 11:50
#204804
Yep, that's it.
FYI
1977 KZ650C1
  • coppertales
07 Apr 2008 12:57
#204818
Thanks guys. I had a hunch it twisted off but I did not want to break anything first. My hi beam is burned out and I need to replace the bulb so I can get my bike inspected. I don't ride at night so I did not miss it.....chris3
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
