few quick questions regarding rear wheel choices for my street/strip killer
- maddogKZ
06 Apr 2008 17:43
well i have my 6 inch extended swingarm and solid rear struts on. now im looking for a wheel
was thinking of a ninja rear wheel to accomodate for a 190 tire or 6 or 7 inch slick
feww questions though. are the axle sizes on those bikes the same>? if not can i sleeve the axle?
also can i use the stock rotor and caliper setup or do i need to custom fab something.?
any input would be appreciated. thanks guys
- donthekawguy
Re: few quick questions regarding rear wheel choices for my street/strip killer
07 Apr 2008 00:21
It might be easier to use the caliper that was used on whatever wheel you choose and build a braket for the arm. That way you know it's right and you will only need to fab up the bracket for the arm.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- tw..
07 Apr 2008 10:29
When I did my rear wheel conversion I looked for a rear wheel with 20mm axle bearings because the swingarm came with a 20mm axle. I also had to go with a 5.5" with rim as a 6 inch rim would not allow me to fit a 190 rear tire. Be prepared to fab some wheel spacers (have plenty of patience on this part as it is the most important part) and that's about all I remember I had to do. Its been a while so I may have forgot something but I think thats pretty much it. Oh I had to clearance the frame so the chain would not hit. A torch and a heavy hammer should do the trick.
Tom
Tom
2-1976 KZ900 A4
1995 KZ1000 Police bike
1978 Z1R
1978 Z1R
- maddogKZ
07 Apr 2008 14:10
what did you do as far as a brake rotor and caliper? did you use the stock equipment?
- racer54
07 Apr 2008 14:17
What did you use to make the wheel spacers? It would be easier to use the whole brake system that was original with whatever wheel you decide to use,but I have seen many KZ's using a 17" 5.5 rear wheel using the stock caliper. Only problem is that the caliper JUST fits and you have to assemble and disassemble the rear brake with the wheel as a unit.
- PLUMMEN
07 Apr 2008 18:03
or you could do like Racer did and mount that bbbbbbbbbbbeeeeeeeeeeeeaaaaaaaaauuuuuuutifull wire wheel on back of your bike!
did i mention i love wire wheels???:laugh:
- racer54
07 Apr 2008 19:10
Man, you must be old like me! LOL I like the newer mags BUT...wire wheels still make me think of REAL bikes. Guess that tells our age, but like seeing the motor on a bike, wire wheels make it a bike.
- PLUMMEN
08 Apr 2008 05:22
exactly!
they quit building cars that really attract my attention after 1970 also!:laugh:
- tw..
09 Apr 2008 08:33
I'm using the complete rear brake system from a 1992 ZX7. As far as spacers I had a few rear wheels lying around with spacers so I had the oversized spacers milled down to fit.
2-1976 KZ900 A4
1978 Z1R
1978 Z1R
- racer54
09 Apr 2008 12:25
They make spacers out of aluminum that are used on dragbikes, but am still trying somewhere to get them. They sell them in length and you cut them to fit, but as I'm not a shop that does this,I am still in the dark. I have an idea where to go,but haven't checked into it yet. Or if you are a machinist, then this isn't a problem like it is for the rest of us mere mortals. Might be an idea to find spacers off any bike with same size axle as I'm sure they are light and make them fit. Unless, of course, you are a machinist and.......
- maddogKZ
13 Apr 2008 01:36
to the top for anyone knowing where they sell wheel spacer stock ... also whats the diameter on the stock axle?
- sramsey216
22 Apr 2008 07:01
I'm also in need of some spacers, anyone out there willing to cut me some?
1980 KZ1000 LTD
