Cannot find a replacement triple tree for KZ650C3 custom 1979. Any help?
  • RetroRiceRocketRider
  • RetroRiceRocketRider's Avatar
  • ...bring in the machine that goes PING!
Re: Cannot find a replacement triple tree for KZ650C3 custom 1979. Any help?
07 Apr 2008 20:06
#204893
You'll want to replace the bearings/races/seals as a set.
It's sort of like when replacing a drive chain, both sprockets should be changed as well since they'll all have related wear to them.
Besides, I don't believe that most places who offer the roller bearings sell them individually.
No tip necessary, just glad to help.:)
If you stick around here long enough, eventually they're will be another person like yourself who'll stumble in here with questions that you'll have a chance to share with what you learned first-hand. B)
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING :-/
07 Apr 2008 20:11
#204894
KZ650C3Custom1979 wrote:
.....Only other factor aside from triple tree is that when riding, more obvious at slower speeds, something around the rotors is clicking and when applying the front brake, it goes away. I can't find a mark on the rotor leading me to believe it is a bump or anything on the rotor. I cannot reproduce the sound when I put it on the stand a simply spin the front wheel. Wonder if rotor is bent? It does brake really well (has duel front rotors as well).Ever heard of this? If not no worries. You've helped enough.
More than likely it's either the speedometer reciever mechanism that is within the front wheel hub that you're hearing (which is normal), my 650 has a similar sound.
OR, it could be that your brake pads are worn and/or slightly loose, which would explain why the sound dissapears when you apply the brakes.
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
  • KZ650C3Custom1979
  • KZ650C3Custom1979's Avatar Topic Author
07 Apr 2008 20:14
#204896
Whoops, that was a misunderstanding. I meant, should I replace both upper and lower steering triple trees even if only the top is busted. Basically, if the top cracked, is it only a matter of time before the bottom blows too or is that not necessarily true? YES, I would replace all the bearings at once.
Gatcha on the helping out.
07 Apr 2008 20:23 - 07 Apr 2008 20:26
#204900
The lower tree is a slightly more solid piece, and IMHO it actually feels like it's made from heavier grade material.
If anything, it will usually bend (ask Bluemeanie about this) before it will break - which could explain why the top tree cracked.:S
The lower tree is a tough piece and it's unlikely that it's cracked, but if you can get a good deal on both upper and lower (undamaged condition of course), then it sure couldn't hurt to replace them both.
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
Last edit: 07 Apr 2008 20:26 by RetroRiceRocketRider.
  • Becker
  • Becker's Avatar
  • The Doctor Will Rise Again
07 Apr 2008 21:04
#204914
I have the whole assembly off of a KZ650b that I'm parted out for the engine. I'd be happy to sell it to you probably cheaper then you could get it on e-bay and I'll check it for straightness before I ship. Just shoot me a PM if your interested. I was gonna put it on e-bay anyway but I'd rather sell it to someones on here if I can.
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
81 CB750K Super Sport
  • EddieBoy
  • EddieBoy's Avatar
07 Apr 2008 22:42
#204923
i am fairly certain that the bottom tree is a steel piece and the top tree is aluminum....probly only need the top but you can have both for the price of shipping....(not to step on any toes Becker).
ive never personally seen a bottom tree break on a 650 that didnt hit a tree...have seen a few top trees cracked though.
its not an extended offer so let me know if you need it
happy to help
EdGe
08 Apr 2008 09:20
#205017
If you don't know what caused the top piece to crack, it's possible that a previous owner hit something. I would replace top and bottom to be safe since you'll have it all pulled apart anyway to replace the lower bearings. Ed
  • Becker
  • Becker's Avatar
08 Apr 2008 21:02
#205130
Haha, no worries EddieBoy. I actually didn't see your post earlier until I just reread the whole forum just now.
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
  • EddieBoy
  • EddieBoy's Avatar
10 Apr 2008 21:14
#205594
heres your new tree....the bottom is steel...top aluminum
  • EddieBoy
  • EddieBoy's Avatar
10 Apr 2008 21:15
#205595
  • EddieBoy
  • EddieBoy's Avatar
10 Apr 2008 21:15
#205596
  • EddieBoy
  • EddieBoy's Avatar
10 Apr 2008 21:16
#205597
