cut off center stand
  • bkay1
  • bkay1's Avatar Topic Author
04 Apr 2008 16:04
#204294
this might be stupid question but is it a good idea to do this or not?
hide the beer... the cops are here
  • Vter Bob
  • Vter Bob's Avatar
Re: cut off center stand
04 Apr 2008 16:15
#204296
It's not a stupid question but I have what may sound like a stupid answer..."It's your bike, do as you please."
On the plus side it will lighten your bike up a little. Some after market exhausts won't allow you to retain the center stand.
On the negative side, it will make doing oil changes and chain maintenance harder unless you have some other method to hold the bike upright with the rear wheel of the ground.
But I must ask, why cut it off? Just remove the spring and unbolt it. :laugh:
Georgia, Vermont
1981 KZ550 LTD
1982 KZ1000 LTD
1999 ZG1000 Concours
Greetings from the Peoples Republic of Vermont, home of Ethan Allen, 2 American Presidents, a socialist US Senator and.....Homer & Bart Simpson
  • bkay1
04 Apr 2008 16:57
#204307
good call man, thanks for the tip
  • Locozuna
  • Locozuna's Avatar
04 Apr 2008 19:08
#204315
76 KZ900LTD didn't come with a center stand cause of the Jardine mufflers but the mounting holes and flanges are still there. My bro bought a centerstand off e-bay and went to hardware store and got 2 big shoulder bolts. When you need a centerstand to do oil changes or wheel adjustments just hang the centerstand. Then when you are done just pull the bolts out and drop the stand. Pretty simple. I didn't get the brains I got the looks. :whistle: :whistle: :whistle: :pinch:
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
05 Apr 2008 07:15
#204380
"When you need a centerstand to do oil changes or wheel adjustments just hang the centerstand. Then when you are done just pull the bolts out and drop the stand."
That was MrJoe72's solution as well:
kzrider.com/index.php?option=com_ponygal...ail&id=1569&Itemid=6
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • PLUMMEN
  • PLUMMEN's Avatar
05 Apr 2008 08:03
#204393
ive always ground the welds off and removed the center stand bracket mounts on my frames.but ive decided to leave them on my turbo bike for some reason which is kind of odd since it will probably only have about 5" of ground clearance between the drain plug and ground!:laugh: thats gonna be a really short center stand!
  • Locozuna
  • Locozuna's Avatar
05 Apr 2008 08:08
#204398
Vern troyer's centerstand!
:woohoo: :woohoo: :woohoo: :woohoo: :woohoo:
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
  • OnkelB
  • OnkelB's Avatar
06 Apr 2008 12:01
#204597
Damn!! :S No wonder the guy in front is puking.
77 KZ 650 B1, 82 GPz 1100 B2.
