BUILDING EXTENDED SWINGARM
- Chopperdaddy
31 Mar 2008 11:22
Did a search but didnt see where this was covered . . . anyone have pointers or pics from there buils ??? It cant be that hard and im going to run struts so nothing specail for the frt mounting point. Like the look of round and square but dont care much for the original ends. I may go with square and make similar to the redline peice. Thinking of 6-8 over for the prostreet look with 150-160 tire. You got pics ??? Or secrets ??? May tool up to do a couple if anyone else around oklahoma is interested in helping and we can build them together ??
Into all things fast. . . Drag boats, bikes and cars . .. sucker for 50\'s thru 70\'s style also
Re: BUILDING EXTENDED SWINGARM
31 Mar 2008 11:52
i am just finishing up a swingarm that i built for my Z1R.it is a plus two with a r1 wheel tire and brake.1" cro-mo.underbraced with r1 axle sliders.i have built several swingarms,for fourwheelers and for bikes big and little.i will post some pics.
31 Mar 2008 11:56
i live in skiatook,and work in tulsa.i do motorcycle machine work and fabricate a-arms and swingarms and stuff at my house in the evening.not trying to advertise,just stating a fact.i have a big lathe,a little mill,mig,tig stick,tubing bender,pretty much whatever i need to fabricate with.
- PLUMMEN
31 Mar 2008 13:45
- donthekawguy
01 Apr 2008 00:00
Hey Leon PM sent.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- jus1975
- www.tripleaperformance.com
19 Apr 2008 20:35
I want to do the same except it will be mono shock and mount a 240 tire. I prefer round.
- PLUMMEN
19 Apr 2008 22:09 - 19 Apr 2008 22:15
i like the look of extended stock arms also,problem being they tend to flex a lot without bracing.those aftermarket square tube swingarms also flex if you put decent power and sticky tire to them:S thats why i like a big beefy looking aluminum swingarm if its something im gonn be putting a lot of power to ground with;)
everytime i see this ltd in th gallery i get a warm feeling but its not intended for putting everything to the ground,sure does look good though!
Last edit: 19 Apr 2008 22:15 by PLUMMEN.
