offset sprocket
- buckracer24
offset sprocket
28 Jan 2006 19:45
can anyone tell me if it is possible to make your own offset sprocket?sprockets i do believe are hardened as i tried turning one in my lathe and all it did was take the edge off my cutter,any info would help.
thanks
Jody
thanks
Jody
- steell
Re: offset sprocket
28 Jan 2006 21:43
Give Sprocket Specialist or JT Sprockets a call and ask what alloy is used in making the sprockets. Then you can determine how to harden it again after annealing it so you can cut it.
Did you use HSS or carbide?
- buckracer24
- bob_z1
Re: offset sprocket
29 Jan 2006 08:37
I took a sprocket for a CBX project and WEDM'd the center out, and then had it welded to another sprocket. that gave us the ofset of one sprocket thick and was enought to clear the 180 rear tire we put on :lol:
- Lorcan
- Speed Loony
Re: offset sprocket
30 Jan 2006 07:33
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
- wiredgeorge
Re: offset sprocket
30 Jan 2006 08:03
The standard Kaw countershaft sprocket nut is a 20mm but the outside uses a 27mm socket. The problem you will find if you need to replace this nut is a standard 20mm nut will generally use a 30mm socket so the hole you make would be well served to accomodate a 30mm socket and also be large enough to bend the tabs on a locking countershaft washer nut.
- buckracer24
Re: offset sprocket
30 Jan 2006 08:08
thanks,i was wondering lorcan how you cut the center out of the sprocket and made it all true and straight.
thanks
Jody
thanks
Jody
- doghouse demon
