replacement seat--82 CSR 1000---something more flat wld be nice?? Any ideas?
- rqs93
- Sometimes it just feels good to go fast!!!!!!!
28 Mar 2008 06:00
I would like to replace my original seat with something
more conventional:( -- something flatter would be nice.
Can seats from other KAW models fit the CSR?
Thanks,
Ron
Thanks,
Ron
- The Gringo
- ¡Usted no necesita otra motocicleta!
Re: replacement seat--82 CSR 1000---something more flat wld be nice?? Any ideas?
28 Mar 2008 06:30
First of all welcome to the forum. You might want to check this thread
kzrider.com/index.php?option=com_kunena&...0212&catid=11#190212
Otto has done a nice job of converting his CSR to a more conventional style of bike and he has documented it well as he went along. I think you will find the info you want in his thread.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
- rqs93
28 Mar 2008 06:37
Thanks
- crusin7
28 Mar 2008 06:46
I can't get this link to open? Also I have a 1982 KZ1300, I would like to put a lower seat on it. Any ideas on this? Thank You.
- JMKZHI
Last edit: 04 Dec 2008 05:49 by JMKZHI.
- rqs93
28 Mar 2008 07:32
I can not get that site to open!!!
- Mcdroid
- Gone Kwackers
28 Mar 2008 08:27
:huh: The link works...try again.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- elcid
30 Mar 2008 15:57
Yeah take off the vinyl cover & get rid of that giant birthday cake sized foam! And replace with some
sunmate
memory foam. This stuff is amazing! Very comfortable with only one inch of foam.
You don't have to be a pro upholsterer. Just cut it to size & put the vinyl cover over it. Stretch it into place & attach to those triangle tabs. Mine looks & feels great. There are many different comfort levels of the memory foam on that site. I would choose the "pudgee" as your top layer & then the go in order below it. I have each layer being a half inch. I started with 3 x .5 inches but then it still seemed too high. So I removed a layer & it feels fine.
Good luck!
Good luck!
- FloridaBiker
31 Mar 2008 05:05
I have the same bike with a flat seat.
I am converting it to a bobber.
Are you interested in my seat?
I can get pictures, if you want.
- rqs93
31 Mar 2008 05:59
Thanks--for the info.
- otakar
31 Mar 2008 06:07
I believe that any of the earlier KZ1000 seats might work. They have hinges like the CSR has and are flat. I can check on my bike if the hinge spacing is the same and let you know. if in fact this works, your possibilities are quite extensive. The GPZ seat I converted was quite a job, a lot of cutting and plastic welding. I do like the GPZ seat quite a bit due to its shape but lots of work. A Z1-R seat might be a bit more easy to convert because of the metal pan. the plastic pan on the GPZ seat makes it a real Bitch to do. (can I say that word here?:blush:)Anything I can help with let me know.
Otto
Otto
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- rqs93
31 Mar 2008 11:27
Hey--thanks for the info. The Z1-R seat which year
model wld be best??
model wld be best??
