Front Fork Disassembly
- oldcuda68
28 Jan 2006 15:44
I am getting ready to replace fork seals and was looking in my manual and they show a long tool to reach down in the forks to hold while removing the allen bolt at the bottom.. Does anyone have specs or what size socket/allen it takes. I will make something if I know the size..Thanks
Mark
Mark
1980 KZ750 LTD
1984 Honda GL1200 Interstate
Too many other toys to mention
- rstnick
Re: Front Fork Disassembly
28 Jan 2006 15:49
Sorry, I don't know the size, but there is some good info in this post:
kzrider.com/forum/viewthread.php?tid=25469
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- wireman
28 Jan 2006 16:11
im not sure of the allen wrench size but if you have an aircompressor and an airratchet you should be able to remove the allen bolt without the t-handle tool to hold the damper.
goodluck,happy wrenchingB)
- oldcuda68
28 Jan 2006 16:22
Thanks Rob and Wireman.
Lots of good stuff in those old posts! Gonna cut up a broom handle after dinner. If it doesn't work. I will try to use the impact.
Mark
Post edited by: oldcuda68, at: 2006/01/28 19:29
Mark
1980 KZ750 LTD
- arobsum
28 Jan 2006 17:54
i never needed the tool when i did mine. the inner mechanism never spun. i removed the allen bolt and took it apart. i guess i got lucky. good luck.
- FireBurst
- kwakagoose
29 Jan 2006 08:19
Here's some pic's of the wooden dowl you need.
Post edited by: kwakagoose, at: 2006/01/29 11:21
- kwakagoose
- kwakagoose
- roy-b-boy-b
29 Jan 2006 08:56
I used a curved piece of tree limb. Ikept it around for several years and finally throwed it out. I got lots of trees. Roy
- wireman
29 Jan 2006 18:14
are you using the wood to reassemble forks?:blink: id be worried about pieces of wood floating around in fork oil.goodluck,happy wrenching!:whistle:
- KZQ
- Administrator
29 Jan 2006 18:49
On my KZ900 it's a round shape with two flats. I bought the special socket from Kaw. I've only used it once. Since then I've always used the impact wrench. It's way faster.
Bill
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
