Looking for ZR1 front brake disks
  • Qdude
  • Qdude's Avatar Topic Author
  • It is all good.
26 Mar 2008 09:08 - 26 Mar 2008 09:13
#202262
I want to buy a set of ZR1 front drilled disks.
Seattle rains. Oh it rains too and sometimes it rains. But other times its just raining.
I am looking for drilled disks to replace the solid ones that I have right now as I've learned that drilled ones work better for wet conditions. (And they just look so damn Kool.)
I've learned via a good thread that ZR1 disks will bolt right up and work with the present calipers.
KZRider is my preferred site for purchases. So, if anyone has a line on a set of ZR1 disks there is a buyer right here. Yours truly.
Cheers,
Q
77 KZ 650 C1.
77 KZ 650 C1.
Last edit: 26 Mar 2008 09:13 by Qdude.
  • OnkelB
  • OnkelB's Avatar
Re: Looking for ZR1 front brake disks
26 Mar 2008 09:23
#202266
Slight correction Q, it´s Z1R - a ZR1 is either a Yamaha or a Corvette.
77 KZ 650 B1, 82 GPz 1100 B2.
  • Qdude
  • It is all good.
26 Mar 2008 11:23
#202291
Yea, what he said !!!
Thanks Oknel ;)
So this dyslexic walks into a Bra....
Should I re-post? Oro do youthink that people will Know that I merely messed up?
Ha ha ha....
77 KZ 650 C1.
77 KZ 650 C1.
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
26 Mar 2008 14:24
#202327
You can edit the heading in your first post. At least you could in the old forum.
You can also find 650 front disks from a '79 or later 650 that already have holes as well. I may have a set from a '79 650C3.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • Qdude
  • It is all good.
26 Mar 2008 16:10
#202350
Any body know the specs for the disks off of a 79 650 C3?
Are they the thicker or thinner.
77 KZ 650 C1.
77 KZ 650 C1.
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
26 Mar 2008 16:37
#202365
I just looked for the C3 disks. I don't have them.
My C2 disks say min. thickness 4 mm.
The Clymer manual say min. 6 mm.
Not sure why the difference. Stamp on the disk is what I'd go by.
I'm sure 650 C or D model disks with holes would work.
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
