Question for NONB and fellow SR and 650 owners
- kzwolfsr
22 Mar 2008 16:35
Have your shocks ever felt like pure rock. I just switched out my old shocks with some used shocks with Mountain, one of our fellow Kzriders and basically I adjusted them to the highest point so that I would get some spring back, but they make the bike feel like one of those hard tail choppers. How do they ride those things? I am now 149lbs and I don't know but would that be to much adjustment for a light guy like me. I don't want to experience a hard tail or the feeling I busted my nuts on the seat! Help Please!
Original man of the Caribbean
Re: Question for NONB and fellow SR and 650 owners
22 Mar 2008 18:53
I could be wrong, but it sounds like you may have adjusted them to their firmest rather than softest setting. Take a look at the adjuster. As you turn it toward the softest setting the spring should relax some and get a bit longer as you reduce the pre-load. Ed
- kzwolfsr
22 Mar 2008 19:33
Well I just adjusted them back down to the lowest setting and tried it out. Not too bad after that test but still a little rough. I must be too light for the suspension to feel me. But however I am impressed with the power the bike has now.....it goes up to 30mph in 1st gear...I nevr seen that before. I will have to read the sparkplugs after some decent riding
- Bluemeanie
23 Mar 2008 06:30
149lbs? With your light weight and "newer" shocks your gonna have to adjust them down a tad. I understand wanting some spring back, apparently these have some so I think you'll still have spring with a softer ride..
- davenkids2001
24 Mar 2008 06:01
650ed wrote:
Ditto on that. I still run stock shocks on my 1979 SR650. I also am not heavy, at only about 170# and my wife is another 100#. So combined we are ~270# and the stock shocks seem to carry us fairly well over all but the worst roads.
I usually set my shocks at the high (stiffest) setting and this seems to be OK with both of us, plus saddlebags and gear.
Dave and Janet
Great Lake State
1979 650SR
Great Lake State
1979 650SR
- kzwolfsr
24 Mar 2008 06:05
I had the shocks on the highest setting but it just jumps around in the back like if I had steel rods. I adjusted it down to the lowest setting....a little softer, but I think the roads here are horrible
