Side cover interchangeability
- Idaho_Spud
15 Oct 2005 22:50
Got a question for the more knowldegeable folks here.
I recently picked up a blue 1979 KZ650B3 that has a broken RH side cover (looks like someone took a spill on this bike at one point, because the headlight bracket is bent as well). The side cover was duct-taped in place when I bought the bike. I'm currently riding the bike daily without it.
Anyway, on to my question: Bikebandit has a blue side cover available for the KZ650-B2/B2A (but not for the B3). Does anyone know if this part would fit and if the paint color would match?
Post edited by: Idaho_Spud, at: 2005/10/16 04:21
- GargantuChet
Re: Side cover interchangeability
16 Oct 2005 08:39
I think that the right side covers are "more" interchangeable than the left. Not sure about paint codes... wonder what buykawasaki.com has to say.
- GargantuChet
16 Oct 2005 08:43
Buykawasaki.com lists red, green, and ebony side covers for the B3. Is it possible that your bike was repainted? Are you sure it's a B3?
- rstnick
16 Oct 2005 11:11
I thought that the B, C and maybe D models had the same side covers, but I think GargantuChet may be right about the Right side one. As the B models do not have the rear master cylinder as the C and D do, there may be a difference in the lower edge. The '77 and '78 side covers have a recess for the side cover emblems where the '79 and later side covers are flat with no recess. Post a picture of yours if you can so they can be compared.
Here's a pic of my '78 C models:
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- RonKZ650
16 Oct 2005 15:32
The B1-3 and C1-3 are the exact same shape and mount for both the left and right and all interchange. The -3 had different emblems. The D model SR covers will also fit but are a different shape with different SR emblems. In other words any 1977-79 KZ650 cover will plug in, but paint will not match. I don't think the blue 1978 KZ650B2 and 1979 B3 are the same, although I really can't remember seeing blue B3s. No difference in the disc brake vs drum models on the covers other than the color.
- Idaho_Spud
16 Oct 2005 18:58
Kewl guys and thanks for all the help. The paint on this bike is faded enough that a new side cover will stand out like a sore thumb - even if it's the correct color, LOL.
It looks identical to the one in the photo, so I probably have a C model. The engine says B and the frame says C, so I guess it's a C then? Anyway, I just want to make sure that whatever I get, it sorta matches in color and definitely matches in fit!
Thanks again for the help and chet thanks for the other link
Mark
Mark
- GargantuChet
16 Oct 2005 19:16
Glad for any help I provided. I've been keeping an eye out for side covers for my '78 SR, so I've been through the parts listings a few times recently.
G'luck!
G'luck!
- rstnick
16 Oct 2005 20:03
Frame says C then it's a C. You should have Mag wheels and disc brakes front and back as well. My engine # is a B # as well. I think they all are.
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
