Fork Caps Air Crossover Line
- TkdFav
16 Mar 2008 11:11
I was doing some looking around on air pressure forks, and I have a few bikes have a cross over for the front forks. Is this factory; if not are they available for KZ's, if it’s even worth it.
- RetroRiceRocketRider
Re: Fork Caps Air Crossover Line
16 Mar 2008 11:28 - 16 Mar 2008 11:33
Is the "cross-over" you're referring to basically a plastic-type hose attached to fittings (one with a shraeder valve) on the top of the fork caps, or a hard line mounted between the upper and lower triple-clamps with a single shraeder valve on the top of only one fork cap?
If it's the plastic-type setup, those are a universal item and replace the original fork caps. IIRC, you'd simply need to know what diameter your current fork cap threads measure at to find the correct setup for your bike.
If it's the hard line type, then that should be an OEM setup. At least it is on my 84 ZN700 and on a lot of other Kawis that I've seen.
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
Last edit: 16 Mar 2008 11:33 by RetroRiceRocketRider.
- TkdFav
16 Mar 2008 11:31
The one I saw was mounted on top with one valve on it. I wouldn't mind either one
16 Mar 2008 11:39
TkdFav wrote:
That would likely be an OEM setup then.
Have you checked at JC Whitney.com or in the Vendor Directory here on KZr yet?
I'm sure at least one of them will have the universal type setup for your bike.
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
- saltydog
19 Mar 2008 11:25
loudfastugly.com/
Has one for 12 bucks!
1981 KZ1000 CSR, 1982 KZ440 ltd, 1972 Honda ct90, 1978 KZ 650
- katjbus
19 Mar 2008 11:42
I would say they are worth it it makes the air pressure the same in both forks so it can only be good
- kzstreetfighter71
- Atlantic West Coast
19 Mar 2008 11:42
i have a setup im not useing for z1 forks, air pressure guage on the top, iodised gold with a braided steel hose, ill take a pic later tonight if you like?
