CAN YOU ADD LINKS TO A 630 CHAIN?
- kenskz1000
Re: CAN YOU ADD LINKS TO A 630 CHAIN?
10 Mar 2008 16:02
Yes, it is possible, but not recommended, because two master links are then required, which doubles the chances of a master link failure.
- StreetfighterKz
10 Mar 2008 16:05
I've had 2 master links on my 1000 for about 4 years now and never had trouble. Most failures are from the clip backing off. If you think about it, the side plates and pins are the same thickness as the other links. Its just that at the very end of the pins where the clip goes they may taper down slightly. I see no trouble with running two.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- kenskz1000
10 Mar 2008 16:06
What I meant was is it possible to rivet links and only use the one master link?
- StreetfighterKz
10 Mar 2008 16:09
Not following. Are you using a rivet style master link as opposed to a clip style?
Later, Doug
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
