1982 KZ 750 17" wheel and tire swap
  • Ituen
  • Ituen's Avatar Topic Author
  • Rider
09 Mar 2008 17:36
#199199
I want to swap on some 17" wheels and tires. I don't want to go too wide in the rear. (I'm thinking about a 17x4.5" wheel and a 160 tire for the rear and a 120 tire on the front). Will a 17x4.5" wheel fit my 1982 KZ750? Do I need a 3/8" offset countershaft sprocket to run the 4.5" rim? I found a 3/8" sprocket for a GPz1100. Will this part work on my KZ750?
1982 KZ750 E
Kawasaki Rider
  • steell
  • steell's Avatar
Re: 1982 KZ 750 17" wheel and tire swap
10 Mar 2008 06:06
#199288
1999-2000 (and probably other years) GSX600/750 front end with 83-85 GPz750 swingarm (modified for dual shock) with GSX750 17" wheels is an easy swap onto a KZ750E. I lengthened the stem by 1/4" and used adapter bearings from All Balls to put the front end on, haven't had time to finish the swingarm swap yet though.
17"x4.5" rear.
  • mjg15
  • mjg15's Avatar
10 Mar 2008 10:58
#199341
I have some Zephyr ZR750 wheels and also a swing arm that I bought a while ago for a project . I decided to go in a more "retro" direction , so I am looking to sell these parts . The wheels are 3.0x17 Fr and 4.0x17 Rr. The swing arm is aluminum w/eccentric adjusters . I believe that I have all the hardware also . 3 Rotors , Rr axle & spacers , cush drive , Rr brake caliper bracket (maybe the cal also , can't remem) . I may even have a pair of ZR550 or ZRX piggyback shock I may be willing to part with . The wheels would go as a pair , but the other items could be separate . If interested PM me .
'80 Z750fx
'81 KZ550A
'81 GPz550's, Too many!
'82 KZ1000R
'82 GPz750
'90 ZR550
Project photo album: s163.photobucket.com/albums/t289/mg15_ph...GPz-ZR550%20project/
s163.photobucket.com/albums/t289/mg15_ph...current=DSC01286.jpg
  • Ituen
  • Rider
10 Mar 2008 16:18
#199400
Can I use my factory KZ750 fork and swingarm or do I need different parts to run 17" wheels and tires?
1982 KZ750 E
Kawasaki Rider
  • Duck
  • Duck's Avatar
  • e vica na i sau na ga
10 Mar 2008 16:27
#199405
Unless you get lucky, brakes will be the headache with stock suspension.
  • Ituen
  • Rider
10 Mar 2008 18:03
#199423
I can't bolt the factory brakes back on the new rims?
1982 KZ750 E
Kawasaki Rider
  • steell
  • steell's Avatar
Re: 1982 KZ 750 17
11 Mar 2008 05:25 - 11 Mar 2008 05:26
#199495
There is no "standard" brake rotor mounting, different number of bolts, different diameters, different bolt circle, ect. And with wider wheels the rotor is moved outboard and hits the swingarm. When doing this type of mods, a decent size lathe, mill, or a friend with a machine shop comes in real handy :)
Generally, swapping the entire suspension is the best way to go to wider wheels.
Last edit: 11 Mar 2008 05:26 by steell.
  • Ituen
  • Rider
12 Mar 2008 12:56
#199755
Should I look for a ZX6R, ZX7R or ZX10 for parts?
1982 KZ750 E
Kawasaki Rider
  • StreetfighterKz
  • StreetfighterKz's Avatar
12 Mar 2008 15:09 - 12 Mar 2008 15:11
#199778
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
Last edit: 12 Mar 2008 15:11 by StreetfighterKz. Reason: Double post
  • StreetfighterKz
Re: 1982 KZ 750 17
12 Mar 2008 15:10 - 12 Mar 2008 15:13
#199779
And none of the new entire suspensions will bolt right in no matter what model or brand except maybe some Ex500 or Gs500 stuff simply due to their smaller overall size. Some early-mid 90's Gsxr stuff will fit with some "minimal" mods but that's about as lucky as you're going to get.
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
Last edit: 12 Mar 2008 15:13 by StreetfighterKz.
  • mjg15
  • mjg15's Avatar
12 Mar 2008 15:33
#199782
Some pics of ZR750 parts that I mentioned above . Your shocks will mount to this swingarm . s163.photobucket.com/albums/t289/mg15_photos/parts/
'80 Z750fx
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
  • Ituen
  • Rider
16 Mar 2008 12:30
#200386
I'm going to start looking for a complete set of ZX6R 636 forks. I think I can fit a 160 tire in my stock swingarm.
1982 KZ750 E
Kawasaki Rider
