Which rear shocks should I use and other questions ???
  • 2M4Dale
  • 2M4Dale's Avatar Topic Author
07 Mar 2008 14:57
#198967
My 80 LTD came with the standard style, preload adjustable, shocks. My 81 LTD parts bike has the shocks with the aditional damper adjustment. Is there any real advantage to the fancier shocks ? Will it be worth the effort to clean 'em up for installation on my good KZ ?
Also ... on these damper adjustable shocks the turning adjustment knob just kindof turns smooth around to the various number marks ... shouldn't there be some kind of dentent of stop at each adjustment ... or is this just the way they are ?
Preload only adjustable on 80 LTD
Preload and damper adjustable on 81 LTD
Hello from Sunny Mansfield, Ohio
1980 KZ750H1 LTD
1981 KZ750H2 LTD
  • 2M4Dale
Re: Which rear shocks should I use and other questions ???
08 Mar 2008 03:20
#199018
hmmm .... no thoughts on this anyone ???
1980 KZ750H1 LTD
1981 KZ750H2 LTD
  • steell
  • steell's Avatar
08 Mar 2008 06:47
#199032
I have both of those shocks as well, and there is no stops or clicks on my adjustable ones either, I think they probably came that way new. I'm going to use the adjustable ones since I already have them, at least until I find a set of ZRX shocks I can afford, I'll be damned if I am going to pay 2/3 the cost of a set of new works shocks for used ZRX shocks :angry:
  • 2M4Dale
08 Mar 2008 08:12
#199042
Thanks steell for the reply. I'm gonna stick with the standard shocks for the short term. Maybe I'll clean and install the fancier shocks later on. I just can't believe there's that much difference anyways. It don't feel like the adjusting knob could possibly be "adjusting" anything !!! ???
1980 KZ750H1 LTD
1981 KZ750H2 LTD
  • JMKZHI
  • JMKZHI's Avatar
Re: .
08 Mar 2008 09:20 - 03 Dec 2008 20:56
#199054
del
Last edit: 03 Dec 2008 20:56 by JMKZHI.
  • 2M4Dale
08 Mar 2008 09:31
#199056
Thanks JMKZHI, that's kindof what I was thinking. I'm wondering if my shocks and steell's shocks are broken and if they could be repaired ???
1980 KZ750H1 LTD
1981 KZ750H2 LTD
  • saxjonz
  • saxjonz's Avatar
  • KawboyZ
08 Mar 2008 11:29
#199064
The only thing I can say about those shocks is for you to make double sure you have both set on the same setting or your bike can get a little squirrely on you. My dad had that problem on his honda 750 when they came out new and he had them set differently probably because I messed around with one of them as a kid. The bike will not handle right and you will notice it especially if someone is riding on back.
79 LTD B3
