Center stand spring?
- Afrosemite
04 Mar 2008 20:36
Anybody have an extra center stand spring that would fit a 78 kz650d or know where I can buy one cheap?
Bikebandit.com wants 7 bucks for one before shipping.
\'78 Kz650d sr
- JMKZHI
Last edit: 03 Dec 2008 20:59 by JMKZHI.
- rstnick
Re: Center stand spring?
05 Mar 2008 06:04
I just took my 650 C2 center stand off, altough I like to keep all original parts. Also should have one from my C3 in a box somewhere.
Should pop up on ebay as mentioned above.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- Bluemeanie
05 Mar 2008 06:28
- RonKZ650
05 Mar 2008 07:16
That spring bluemeanie shows there is the correct spring. However the part is superceded by 34023-016 and listed at Bikebandit for $6.93. Should be easy to order.
- OKC_Kent
05 Mar 2008 09:59
And once you get your spring you get to use the coin trick to install it.
Bend the spring to create a gap between the coils and insert a penny in the gap. Do this over and over until the spring stretches far enough to fit over the pins. It might take 5 or 6 pennies. Then extend the center stand and the coins fall out.
I love the tips I learned on this forum..
Cashion, OK
78 KZ650 B2 85,000+ miles
