frame differences
- jake72ss
frame differences
25 Jan 2006 06:17
I would like to know what the difference is between the frame on an ELR type kz and the frame on the earlier(pre '80) frame. Several years ago I owned a kz1000ltd I think it was a '78 or '79 model. Anyways I have the option to buy the bike again and would like to make it more of an ELR type of bike. Thanks for any help. Jake
- wireman
- steell
- wireman
- craigpuckett
Re: frame differences
27 Jan 2006 11:33
the 81-82 Jmodel/ELR/GPZ frame has more bracing,uses different motor mounts,bigger forks,seat does not have hinges,almost nothing interchanges.
the 81-82 LTD/CSR frame has a hinged seat,bolted on gas tank,no bodywork in the rear,again almost nothing interchanges with pre 1980 frames.
I don't know about the 83-84 frames.
- Mcdroid
- Gone Kwackers
27 Jan 2006 12:33
Jake, I have seen a number of pre-1981 Z's that have been ELRicized. The trick (to the eye) is one of primary use of the paint schemes of the 1982/3 ELRs. However, since little swaps between pre- and post-1980 bikes, you are stuck with either LTD or standard body styles (unless you really want to get into fabricating mounts, etc., then anything is possible). Use the standard body style as size-wise, it more closely approximates the tank sizes of the GPz/ELR lines. Many of the early KZ model ELR clones I have seen have been very nice...some, less so :S
Post edited by: Mcdroid, at: 2006/01/27 15:34
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- Jeff.Saunders
27 Jan 2006 17:22
The ELR uses a completely different frame - the rake/trail is different for sure - don't remember the degree difference, but it's a degree or two
- kano
- Not Another Bloody Limey!
26 Nov 2006 18:29
Jeff.Saunders wrote:
angle (from 27.5 to 29.0 degrees, adding 0.6 inched of trail),
a different headThe ELR uses a completely different frame - the rake/trail is different for sure - don't remember the degree difference, but it's a degree or two
- kano
26 Nov 2006 18:30 - 28 Oct 2008 19:00
yeh its a little confusing,
now we have it documented on the best place for kz er's
anyone else who needs or wants to know can find info.
kzrider.com/index.php?option=com_kunena&...tid=5&id=88865#88865
Last edit: 28 Oct 2008 19:00 by kano.
- DRD
06 Jun 2007 17:02
I HAVE A 82 LTD 1000 AND I WAS WANTING TO MAKE IT LOOK LIKE A KZ 1000.WHAT WILL INTERCHANGE AND WHAT ARE THE DIFFERENCES IN THE FRAMES.THANKS DONNIE
