How to widen frame?
  • kayzednutcase
  • kayzednutcase's Avatar Topic Author
How to widen frame?
21 Feb 2008 18:38
#196161
I have a 1977 KZ1000 frame and i would like to install a really nice Honda swingarm/ monoshock set up that i have. The problem is that the swingarm pivot point is 1" wider than the frame pivot point. The swingarm cannot be made shorter, it's impossible, so any ideas on widing the frame without it getting twisted? And once it's done, how do i check that it's really straight? Is this a job for a professional shop?
Thanks
B
  • PLUMMEN
  • PLUMMEN's Avatar
Re: How to widen frame?
21 Feb 2008 19:14
#196169
narrowing swingarm or finding narrower arm would be much easier than widening swingarm mounting area.;)
  • kayzednutcase
21 Feb 2008 19:46
#196178
I agree but isn't this a nice looking swingarm?
  • kayzednutcase
21 Feb 2008 19:48
#196180
Trya again..
  • PLUMMEN
  • PLUMMEN's Avatar
21 Feb 2008 19:51
#196182
im kinda partial to this one myself,if it ever gets finished anyway!:P suzuki swingarms tend to work really good widthwise,check solomrus's swingarm swap i think he used a 600 kawasaki or something like that that looked similar to yours;)
Post edited by: PLUMMEN, at: 2008/02/21 23:32
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
22 Feb 2008 07:45
#196240
i think mill .500 off each side,some solid bronze bushings and it is in there.i have had to do that to put late model honda swingarms in older chassis(f3-f4 maybe).or cut it off build a new pivot tube and weld it back on.i just hate to make chassis modifications,when i can modify the part itself.thats my take anyway,fwiw.
  • StreetfighterKz
  • StreetfighterKz's Avatar
22 Feb 2008 08:48
#196256
531blackbanshee wrote:
i think mill .500 off each side,some solid bronze bushings and it is in there.i have had to do that to put late model honda swingarms in older chassis or cut it off build a new pivot tube and weld it back on.
Due to the way that the arm is cast I'm not sure he can just cut off what he can't use. I'd be leary of welding on to a cast part like that. Now if it was extruded or machined like that I wouldn't think twice. But welding to a cast part that's in such a high stress area would scare the crap outta me.
I think if he really wants to use the arm he can either widen the frame OR grab a Kz100ST frame which is a couple inches wider.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • 531blackbanshee
  • Vendor
  • Vendor
22 Feb 2008 09:05
#196262
the factory sure didn't hesitate to weld on it.
  • hardr0ck68
  • hardr0ck68's Avatar
  • Who put the what in the where?
22 Feb 2008 09:21
#196266
what shocks me are the shock mounts. For all the ruggednesses of a built swingarm thay are such little guys...I have often thought if they can handle the load than the swingarm will be more than able.
Just my thought... prove me wrong and show me a swingarm swap that also reinforced the shock mounts!! (i would honestly be happy because i have a zrx1100 rear end, that I plan on adding to my 650...I want to know how to do it right!)
Post edited by: hardr0ck68, at: 2008/02/22 12:22
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
  • 77KZ650
  • 77KZ650's Avatar
22 Feb 2008 09:54
#196276
crude 30 sec MSpaint pic of what i would do:
just get a good machinist/welder to do it
Post edited by: 77KZ650, at: 2008/02/22 12:55
07 MDP Rookie of the Year
  • StreetfighterKz
22 Feb 2008 10:29
#196281
True...point taken.
Post edited by: StreetfighterKz, at: 2008/02/22 13:36
1979 z650 Resto-Mod
2018 Z900RS
