swingarm bearing
  • The Dude
  • The Dude's Avatar Topic Author
swingarm bearing
23 Jan 2006 20:05
#19570
How do I get those things out of there. Theres 2 total, one on each end.
  • Snakebyte
  • Snakebyte's Avatar
Re: swingarm bearing
23 Jan 2006 23:17
#19587
Cut off a broom handle and use a hammer.:P
  • donthekawguy
  • donthekawguy's Avatar
24 Jan 2006 05:50
#19603
A long rod and a BFH should do it.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • wiredgeorge
  • wiredgeorge's Avatar
24 Jan 2006 06:31
#19612
Both folks have suggested a tool called a drift. I don't use broom handles as I like something more solid to whack with my BFH! Go to any hole improvement store and buy and aluminum bar. Get at least 5/8" thick bar and one that is about 2" long. I use this thing to drive out axles and bearings and it makes a handy tool. If you have to drive out sticky bearings, like in a steering head, you will need the solid metal to do the driving.
  • The Dude
24 Jan 2006 06:38
#19613
Thanks guys, thats kinda what I thought. The last time I used that method on our ATV the bearing just broke apart and it was a lot of work getting them out. Hopefully this goes better than that.
  • RonKZ650
  • RonKZ650's Avatar
24 Jan 2006 08:33
#19623
I doub't beating on them will budge them. If not, get a dremmel tool out and grind them to weaken them enough to break as you hammer on them.
  • BohicaBob
  • BohicaBob's Avatar
24 Jan 2006 15:17
#19713
I'd try my inside bearing puller first, assuming the tool would have enough room to work between the needle bearing's (Part #92046-1115) cage and the swing arm sleeve (Part #42036-1017). Otherwise, use a drift. In either case, first heat the outside area of the swingarm that contains the bearing with the wife's hair dryer.:)
  • The Dude
25 Jan 2006 11:56
#19851
I broke down and bought a dremel. That little thing is amazing!
  • hwms
  • hwms's Avatar
25 Jan 2006 12:09
#19854
Delete
Post edited by: hwms, at: 2006/01/25 19:18
