wider rims
- Rob
wider rims
19 Feb 2008 07:49
is it possible to take a factory cast rim and have it wided. or and im just daydreaming again!
reason i ask is i was looking through the kz1000 pictures and seen Deans kaw and the rear wheel looks like a factory rim but wider.
Thanks
Rob
Thanks
Rob
Located in Cleveland, Ohio
78 kz1000LTD (project)
- Samwell
Re: wider rims
19 Feb 2008 07:55
Rob wrote:
Yep, it can be done. Not cheap, but certainly doable.
Check out: www.kosman.net/ look for weld-up wheels.
Sam
Thanks
Rob
Sam
- Rob
Re: wider rims
19 Feb 2008 08:09
Thanks Sam i will be checking into that.
- StreetfighterKz
Re: wider rims
19 Feb 2008 09:03
79MKII has his rear modded from a 16x3 to a 17x6 by Klasmo in Germany. I'm not sure if he modded his front wheel.
Just rember pretty much any rim wider than stock will require a different swingarm.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- Rob
Re: wider rims
19 Feb 2008 09:41
Thanks Doug, yeah im using a redline 2 inch over swingarm so i think im good there. talked with kosman 425 to add half inch on both sides of rim, leaving diameter of rim at 16.
thinking i may do this.
Rob
Rob
- 79MKII
- Love Them Kaws!
Re: wider rims
19 Feb 2008 10:16
Yep, rear done at Klasmo, front done at Kosman. I also had another rear done as Kosman a while ago. Both places do nice work. The welds are visible on the kosman wheel but they claim that makes it stronger. I widened an 18" Z1-R front to 3.5" so I could get a nice set of matching radials. I'd go 5.5" on the rear instead of 6" if I had to do over. Clearance was a pita.
Kosmans web site explains the whole process really well. Just be sure you specify which type of rim you want - they offer 2 styles. Keep us posted with plenty of pictures and details!
Mike
Mike
The Kaw List:
- Rob
Re: wider rims
19 Feb 2008 10:58
hey mike you dont happen to have any pics of the finished kosman rim by chance.
and you think 5.5 is a good way to go?
Rob
Rob
- 79MKII
- Love Them Kaws!
Re: wider rims
19 Feb 2008 14:14
I'll try posting some pictures:
Here is the first wheel I had done, this is the style I didn't like so I ended up selling it. This was a 2.15" rear bumped up to 3.5" by Kosman.
The Kaw List:
- 79MKII
- Love Them Kaws!
Re: wider rims
19 Feb 2008 14:15
The Kaw List:
- 79MKII
- Love Them Kaws!
Re: wider rims
19 Feb 2008 14:17
This is a shot of the 2.15"x18" front wheel that I had widened to 3.5" for radial tires. This rim style is more like the standard KZ style. I just didn't like the looks of the other smooth style.
The Kaw List:
- 79MKII
- Love Them Kaws!
Re: wider rims
19 Feb 2008 14:23
OK, finally here is the rear wheel that I had done Klasmo. This was a 3.00 x 16 LTD wheel that I had widened to a 6.00 x 17. The Klasmo wheel has no visible weld, and they swear they are 100% safe and have been tested on the autobahn. All of these wheels need finished when you get them - either polished, painted, plated, etc... I think around 3.5-4.0 is as far as you can go without using offset sprockets and spacers and all of that stuff. That might be the way to go. Should be a lot easier to set up, anyway.
The Kaw List:
- 79MKII
- Love Them Kaws!
Re: wider rims
19 Feb 2008 14:53
The Kaw List:
