Tricks for removing dust boot?
  • Link14
  • Link14's Avatar Topic Author
19 Feb 2008 06:42
#195518
Was going to start another sub-project on the kz750 last night....change the fork oil. A friend of mine said I should check under the dust boots to make sure the fork seals aren't leaking. Fortunately the boots on the 750 almost look new, no cracks or splits (unlike my 400's). Unfortunately some gentle prying along the bottom edge with a screwdriver showed me that they are on there really well.
Could anyone share any successful techniques on removing these boots?
  • JMKZHI
  • JMKZHI's Avatar
Re: .
19 Feb 2008 06:53 - 03 Dec 2008 20:43
#195523
del
Last edit: 03 Dec 2008 20:43 by JMKZHI.
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: Tricks for removing dust boot?
19 Feb 2008 08:20
#195544
Well, if your fork seals were leaking, fork oil would be dripping down your fork lowers and you wouldn't have to peek under the dust covers to ascertain leakage:) But, if you must look, a thin, flat screwdriver inserted gently under the edge and run around the entire fork should force the cover up and off.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • old650
  • old650's Avatar
19 Feb 2008 14:26
#195625
Speaking of which. I have an extra set of forks and a pack of new seals sitting around. I know that there are plenty of threads on rebuilding/installing new seals/oil etc. but...... On a realistic 1-10 scale is refurbishing a set of forks fairly easy or a major pain in the hole? My right fork seal on the bike now is leaking and I've previously changed out with new/proper fork oil. Maybe I should get off my duff and do up these extra forks and pop them onto the bike.
  • JMKZHI
  • JMKZHI's Avatar
Re: .
19 Feb 2008 16:30 - 03 Dec 2008 20:53
#195652
del
Last edit: 03 Dec 2008 20:53 by JMKZHI.
  • old650
  • old650's Avatar
20 Feb 2008 12:50
#195871
JMKZHI wrote:
Doing forks is easy the second time. There's a learning curve on the first go around.
When I did the ones on my 81 650, here's where I got stuck:
Top caps or plugs. They wouldn't budge. Then I used heat applied w a propane torch - they came right out.
Bottom allen bolt & inner cylinder. A rake handle carved into the shape of a cone then jammed into the head of the inner cylinder works for holding it steady while unscrewing the bottom allen bolt. Some folks have had success by simply hitting the allen bolt w an air impact wrench.
Pulling the old fork seals. I'd never pulled a seal before, so it took some leanin to figure it out. I used an off the shelf seal puller from the auto parts store & used a very small block of wood (~1x1x6) to lever against, doing it at the end of a work bench.
I made a seal driver out of 1-1/2 pvc pipe & fittings. JMK.
Interesting observations and good tips. Thanks buddy, I'm tucking this one away for future reference.
  • Link14
20 Feb 2008 18:40
#195936
Ok, Mcdroid convinced me.....since I already have the oil (didn't realize SAE 10W was so hard to find), I think I'll drain'em, top them off and then pressure them up. If it starts to leak, I'll order some seals..
Thanks!
