new bars, spinning controls
  • smd
  • smd's Avatar Topic Author
13 Feb 2008 14:07
#194426
Hey everyone--
Currently in the process of putting superbike bars on my '82 CSR 1000. I've got the new bars on, new clutch cable, relocated the turn signals, etc. But what I can't figure out is how to keep the controls on either side fixed in place. I've got just two screws that clamp the control housing around the bar, but if there's supposed to be an anchoring screw or something like that I'm missing it. I'm also mising whatever's supposed to keep the throttle cable snug in its notch in the underside of the control housing. Any help is appreciated.
-Steve
  • BSKZ650
  • BSKZ650's Avatar
Re: new bars, spinning controls
13 Feb 2008 14:27
#194432
I think you may have some bars that are too small, if you have a pair of cailpers, check the old ones and new, I think you will find a size problem
77 ltd1000, current rider
76 kz900, just waiting
  • smd
13 Feb 2008 14:29
#194433
I checked the diameter of the bars, and they're the same: 0.875.
Thanks.
  • Locozuna
  • Locozuna's Avatar
13 Feb 2008 14:40
#194436
Check the control pods. Some have a little notch that fit into a hole in the orig bars. You can dremmel it off and they should clamp pretty tight unless you have flexed the pods trying to tighten them. Or you can drill a hole in the bars but be careful to have the pods in the position you want since they will not be adjustable after.
I'm not sure what you mean about the throttle cables. can you get a picture?
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
  • flht1997
  • flht1997's Avatar
13 Feb 2008 15:26
#194444
if the bars are just a smidge under 7/8 the controls may rotate. one quick and dirty is to mark where the controls are, then take the bars off and whack the mark with a hammer and the bars on the floor. they are now oval and the controls round, instant interferance and no more spinning. you can also grind a little bit off the parting line on the controls to pinch a little more.
Matt Milwaukee, WI
75' KZ400, (5) 78' KZ400, 76' KZ 750, 78' KZ650
78'CB750F, 78' CB550K
89' BMW R100RT
05' H-D Electra Glide
06' KLR650
Do it right or don't bother doing it at all.
  • brokenrod
  • brokenrod's Avatar
13 Feb 2008 19:11
#194480
you can cut a small, thin rubber strip about the size of a bandaid and use it as a bushing between the bars and the controls. did that on my kz750 and worked fine for years.
I started out with nothing, and still have most of it...
1981 GPZ1100, 1981 kz1000m1(csr), 1979 suzuki gs425
