Swaying
- seanof30306
Re: Swaying
08 Feb 2008 14:30
Ok, did some checking as per recommendations above. There is no movement in the stem whatsoever.
There does appear to be just a little bit of give in the swingarm. How much is acceptable? Also, does it matter if you check with the rear shocks hooked up?
Also, not to call out any names, or anything, but a certain leadfooted hot rodding maniac speed demon mechanic whose initials are jccwall just "accidentally" broke the chain while out on a "test ride". I'd noticed the chain was a little loose when I looked at the rear wheel after it started and stopped the swaying the other night. Could the chain somehow be involved in the swaying?
Post edited by: seanof30306, at: 2008/02/08 17:35
"That @#$%!!! KZ650"
79 KZ650 B3
Dual front disc brakes
Z1R 18" front wheel
Pumper carbs w/pods
MAC 4-1 w/ drilled-out baffle
Dyna S ignition w/ Dyna Green coils
WG coil mod
'81 CSR charging system
17/41 gearing
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
- Bluemeanie
Re: Swaying
08 Feb 2008 14:48
I would think you might get a better "feel" if shocks were unhooked. Just remember that swingarm will drop to floor when last shock bolt comes out!
And not that it's causing your problem but I would drop tire pressure back to specs. Check sprockets, now is the time to change them also, a new chain on old worn out sprockets is a waste of money. Z1 has all parts you need.
Post edited by: Bluemeanie, at: 2008/02/08 17:51
- seanof30306
Re: Swaying
08 Feb 2008 14:56
Bluemeanie wrote:
Sigh .... yes, I know Z1 has the parts. I should be a stockholder by now.
Stock is 530, right? Since I have to replace the chain and sprockets, is there a better size?
Post edited by: seanof30306, at: 2008/02/08 18:36
Check sprockets, now is the time to change them also, a new chain on old worn out sprockets is a waste of money. Z1 has all parts you need.<br><br>Post edited by: Bluemeanie, at: 2008/02/08 17:51
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
- Bluemeanie
Re: Swaying
08 Feb 2008 16:02
Yes, it's a 530. If it's a standard KZ650 (not a CSR) stock gearing should be 16/42. I ran 15/42 for about 15 years, better accelleration, about 500rpm higher at 70mph. On WOT 1st gear comes up REAL fast, going back to 16/42 bike is much more ridable. You could go 17 on front (make sure enough room) or drop a few teeth (not sure how many) on rear to drop your highway rpm's. Don't drop too much as you'll have to ride your clutch to take off. But 16/42 is factory setup. Sprocket size really depends what kind of riding you want to do.
- Vintagejunkie
Re: Swaying
12 Feb 2008 08:06
Its a long shot, maybe when the rear bushings get warm they loosen up. I have a pair of brass bushes on order myself. if you are pulling the rear wheel and chain anyways.....:whistle:
- seanof30306
Re: Swaying
13 Feb 2008 08:59
Ok,
With the rear shocks off, there is just a little movement in the swingarm.
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
- gpzrox
Re: Swaying
14 Feb 2008 02:56
seanof30306 wrote:
None.
Ok,
None.
84 GPZ750. Modded with stock Kawasaki parts: ZR-7 shock, ZX-6 coils, GPZ1100 throttle, EN454 brake, GPZ900 fuse box, etc. and non stock: Ken Sears mirrors, K&N filter, Pirelli Sport Demons.
- Biquetoast
- King Jeremy The Wicked
Re: Swaying
14 Feb 2008 03:50
seanof30306 wrote:
There should be no movement whatsoever.
I remember one of mine had just 1/4 inch of movement and I could feel it like you describe. I ended up re-doing the bearings (my model had bearings, not bushings) and it solved the problem.
Ok,
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
kz750twins.com
- Bluemeanie
Re: Swaying
18 Feb 2008 07:49
seanof30306, any progress on your "swaying"???
We like to hear if we solved the problem, also lets the next guy with same prob know most likely cause. Thanks...
Post edited by: Bluemeanie, at: 2008/02/18 10:51
- seanof30306
Re: Swaying
18 Feb 2008 09:40
I ordered swaybar bushings and wheel bearings just to be sure. Hope they'll be in any day now. Will update.
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
- jccwall
Re: Swaying
26 Feb 2008 13:46
update,
replaced swingarm bushings and new chain and sprockets. as of saturday and monday morning no swaying noticed.
"leadfooted hotrodding maniac mechanic"
- seanof30306
Re: Swaying
31 Mar 2008 22:33
Replaced the swingarm bushings. Since we were replacing the rear sprocket, too, I figure we might as well put in new wheel bearings as well.
I've put about 200 miles on it, so far, and it's been perfect.
Thanks for the help.
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
