ZX636 Front End to KZ900 Tutorial: Old Man Rock
- Old Man Rock
03 Feb 2008 05:39
Here you go....
ZX636 to KZ900 Front End.
members.cox.net/ruinsofstei/Old%20Man%20...End%20Conversion.pdf
Just in case you missed it, ZX6R Swing Arm conversion.
members.cox.net/ruinsofstei/Old%20Man%20...Arm%20Conversion.pdf
[img size=150]C:\Kawasaki KZ 900\2005 zx6r(636) Front End Swap\P1000441resized.JPG[/img]
Hope you enjoy,
Old Man Rock
Post edited by: Old Man Rock, at: 2008/02/03 08:41
Hope you enjoy,
Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- kano
- Not Another Bloody Limey!
- circusnuts
Re: ZX636 Front End to KZ900 Tutorial: Old Man Rock
05 Feb 2008 18:35
This is very very cool and thany you for posting.
Question:
Doesn't the bike that these parts originally mounted to weigh a whole bunch less that a KZ900?
I have a ZX10 and it weighs something around 400 lbs with oil and gas.
Post edited by: circusnuts, at: 2008/02/05 21:37
Question:
- Old Man Rock
06 Feb 2008 05:50
circusnuts,
"Doesn't the bike that these parts originally mounted to weigh a whole bunch less that a KZ900?"
If your speaking of the ZX6 part weights in comparison with KZ weights than I assume so....
Or is your question more in the regards while riding to the front end coming up on me due to the weight change?
Outside of that, not really sure what your question is.
Old Man Rock
Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- StreetfighterKz
06 Feb 2008 08:53
circusnuts wrote:
Yes the Kz weighs more but normally sportbikes have a stiffer spring rate to begin with than a Kz does.
I did some research on Race Tech's website and couldn't find a Kz900 but found that a 82-83 GPz550 has a front spring rate of .393kg/mm while a 04-05 Zx-10R has a front spring rate of 1.00kg/mm or almost 3 times as stiff.
Now granted the 550 will have a lighter spring than a 900 but not by a whole lot.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- circusnuts
06 Feb 2008 12:18
Just thinking the fitment might not be to good if you're looking to run the bike hard.
Albeit the spring rates on the 600 and 1000cc sportbikes are stiff enough, I can tell you from personal experience with my ZX10 that Kawai shaves weight everywhere... which I cannot help but think could be a strength disadvantage when using parts to crossover.
For instance, my 04 had a wheel recall for cracking, the foot pegs were notorious for breaking on riders weighing anything close to 200 lbs and if you rode the bike with any intensity you could expect to replace a set of fork seals each season.
Having said all of this, I think you work is very very cool and thank you for sharing.
Post edited by: circusnuts, at: 2008/02/06 15:20
- Old Man Rock
07 Feb 2008 05:08
Whoa, you guys nearly loss me there with all the kg/mm weight differences and such...lol!
Due to newer technology weight/compression ratios and all I'm not worried about these concerns for one main reason....
This old man will not be riding her hard to he level of > 100mph nor will I be trying nose wheelies, rear wheelies or anything as such that would cause me to crap my pants... :woohoo:
Thanks guys for I hadn't thought of those issues,
Old Man Rock
Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Boostable
03 Oct 2011 10:43
OMR.. Sorry to dig up this old post, but do you still have these posted some where?
Thanks,
Thanks,
~Jack
1982 KZ1000 J2 ~ Project (Street Fighter - Project Section)
1976 KZ900 - Daily Rider
- abelseth
03 Oct 2011 11:31
Cant open the links :S
- abelseth
04 Oct 2011 16:15
Thanks
Got the "Just in case you missed it, ZX6R Swing Arm conversion.
members.cox.net/ruinsofstei/Old%20Man%20...Arm%20Conversion.pdf" as well?
Got the "Just in case you missed it, ZX6R Swing Arm conversion.members.cox.net/ruinsofstei/Old%20Man%20...Arm%20Conversion.pdf" as well?
- Old Man Rock
05 Oct 2011 09:04
Here ya go...
NOTE: After seeing some others work
and how they accomplished, I'd change the top mounting some.
for a cleaner look... I wanted everything tucked up behind the side covers so all good. Just would change a few things.
zx-6rr-swing-arm
zx-6rr-swing-arm
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
