shaft removal help
  • mpatrick19
  • mpatrick19's Avatar Topic Author
  • 1982 kz750 spectre
shaft removal help
02 Feb 2008 13:51
#192418
i have decided to change my shift shaft, and i need to get that cover off, i need to know the process of getting it off, its a shaft drive so i assume there is some special trick to getting the shaft apart from the case. Please help im stuck.
thanks, mike
1982 kz750 spectre
  • OKC_Kent
  • OKC_Kent's Avatar
Re: shaft removal help
02 Feb 2008 17:06
#192461
Can you update your post to let us know what particular bike you're talking about? You can go into your forum Profile and add this information, and your location, to a Signature block.
Do you own a shop manual?
Cashion, OK
78 KZ650 B2 85,000+ miles
  • johnp
  • johnp's Avatar
02 Feb 2008 17:32
#192466
the rubber boot at the front of the dr. shaft move it forward rotate shaft look at the smooth ring front of dr. shaft u'll see a hole..insert a drift pin and push about 3/16 in. it is a small hole..the dr. shaft will free up..besst luck
  • mpatrick19
02 Feb 2008 21:11
#192491
ok i got it out and replaced the shifter shaft now i can not for life of me get the drive shaft back on the splines. is there a trick or something. i do have a shop manual but its useless for this problem.
1982 kz750 spectre
  • mpatrick19
02 Feb 2008 21:14
#192492
1982 kz750 spectre
  • mpatrick19
03 Feb 2008 10:49
#192574
i held my mouth just right, and got it all back together. thanks guys.
1982 kz750 spectre
