Size Matters? (Rear master cylinder)
  • 79MKII
  • 79MKII's Avatar Topic Author
  • Love Them Kaws!
Re: Size Matters? (Rear master cylinder)
20 Feb 2008 03:45
#195762
Wow, I assumed that all of the trapezoidal MC's were the same.
Do you know if the rear MC's were switched too?? I have 2 rear MC's that look identical, but one has 5/8 cast into it and the other 14. Do you think that's 14mm??
The Kaw List:
20 Feb 2008 04:48
#195764
79MKII wrote:
...Do you know if the rear MC's were switched too?? I have 2 rear MC's that look identical, but one has 5/8 cast into it and the other 14. Do you think that's 14mm??
Per FSM, the rear m/c introduced on 1976 KZ900-B1 LTD is size 5/8. And size 5/8 rear m/c continues with 1977-1979 KZ1000 models.
Sorry I don't know about rear m/c sizes in 1980 and later. Would have guessed continuing with 5/8 after 1979, but would concur with your thinking the 14 means 14mm (subject to actual measure of bore diameter).
Am thinking the smaller 14mm rear m/c is more sensitive (having more braking power with less pedal pressure) when compared with larger 5/8 size m/c. And therefore easier to "lock up" the rear wheel when braking.
EDIT: The Brembo rear caliper may be designed for optimal rear braking performance with a 14mm m/c.
Good Luck! :)
Post edited by: Patton, at: 2008/02/20 07:57
  • 79MKII
  • Love Them Kaws!
20 Feb 2008 11:33
#195846
Thanks for all of the info guys. I'm starting a new thread for the Master Cylinder ID. I might want to rebuild the 14mm unit but I'm not sure what bike it came from originally. I also plan to disassemble and directly compare to my stock 5/8" MC.
Here's the new posting:
New Thread Here
The Kaw List:
