Throttle Lock at DENNISKIRK ?
  • route66paul
  • route66paul's Avatar
Re: Throttle Lock at DENNISKIRK ?
03 Feb 2008 13:43
#192603
you can use a big rubber o-ring. It will keep the throttle constant by friction, but you can still adjust the throttle. When you get off the highway, you can roll it back onto the grip. Cost - $.80
  • old650
  • old650's Avatar Topic Author
04 Feb 2008 02:39
#192677
Thanks for the tips guys, I appreciate it.
  • seanof30306
  • seanof30306's Avatar
09 Feb 2008 10:03
#193610
What size o-ring did you use? Do you have a pic?
"That @#$%!!! KZ650"
79 KZ650 B3
Dual front disc brakes
Z1R 18" front wheel
Pumper carbs w/pods
MAC 4-1 w/ drilled-out baffle
Dyna S ignition w/ Dyna Green coils
WG coil mod
'81 CSR charging system
17/41 gearing
  • old650
13 Feb 2008 06:03
#194368
bill_wilcox100 wrote:
I even went for a lighter throttle spring from Canadian Tire so that I don't feel like I'm fighting the bike mile after mile. Works for me. ;)
Post edited by: bill_wilcox100, at: 2008/02/02 12:24<br><br>Post edited by: bill_wilcox100, at: 2008/02/03 16:50
Looking at this again, the lighter spring sounds like a feasible option. You do mean the heavy spring on the carb rack right? Is there a descriptor/designation for this spring or did you bring the rack spring in for size, do some pull strength comparisons and basicly guestimate it out?
  • bill_wilcox100
  • bill_wilcox100's Avatar
13 Feb 2008 07:39
#194377
Since my cables were new and my carb linkage was lubricagted the carb action was smooth and effortless without any return spring in place
I took the orginal spring with me Canadian tire and went to the section that has accessoris like window crand handles and the like. I found a few springs in that section. Then I just took one of the springs out of it package and it felt like about 1/4 to 1/3 of the the pull so I tried it.
Took it home and installed it. That's it, that's all. Sorry, no science to my method at all.
I suspected this was do-able since I had to do things like that to make my HD work when I was a kid.
Best of success.
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
13 Feb 2008 11:46
#194414
I had a throttle lock on my bike years ago and liked it. Can't remember what happened to it.
I now have one of those throttle rockers like in bluemeanies post and like it as well. Lets me rest my hand when I want, but not remove my hand from the bars.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • seanof30306
03 Mar 2008 20:24
#198256
1982KZ1100D1 wrote:
watch ebay. I got two new "Dixie brand" for $10 each including shipping a few weeks ago. Put one on the KZ and the other on the Vulcan.:cheer: I had to cut off the lower flange that is supposed to fit between the throttle cables and add a small screw through the nylon to the throttle housing. I've had one done like this on my Honda for over 100K miles now with no problems.
  • <br><br>Post edited by: 1982KZ1100D1, at: 2008/02/02 07:44
    I've checked ebay, but, can't find any for less than 30 bucks. Can you post the seller's ID?
    Also, my bike has aftermarket, foam grips. Will this create a problem?
    79 KZ650 B3
    Z1R 18" front wheel
    Pumper carbs w/pods
    WG coil mod
    17/41 gearing
    03 Mar 2008 20:45
    #198260
    seanof30306 wrote:
    ...bike has aftermarket, foam grips. Will this create a problem?
    Grip style doesn't matter, as the fixture simply clamps around the throttle tube, with tightness of the clamp being adjustable to personal preference. The clamp performs the same on a naked throttle tube without any handlebar grip. :)
