Brake pad replacement
  • ThatGPzGuy
  • ThatGPzGuy's Avatar Topic Author
  • Away
31 Jan 2008 12:44
#192024
I am trying to get everything buttoned up from my fork rebuild. I want to pull the brakes apart and clean the pads to get all the accumulated junk and fork oil out. I was looking at the caliper last night and I tried to pull the pads but they did not come out. Is something holding them in or do they come straight out? Is there any danger in spraying the whole mess with brakekleen (the new enviromentaly friendly green one)?
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
Re: Brake pad replacement
31 Jan 2008 14:00
#192041
Just to confirm, is this the oem brake system on the 1982 GPZ750 shown in your signature line?
  • ThatGPzGuy
  • Away
31 Jan 2008 15:31
#192059
Yep
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
31 Jan 2008 15:59
#192067
Here's the parts diagram for reference. :)
Hope someone more familiar with this particular caliper will offer better specific advice.
On the Z1 and KZ900 front caliper, one pad is held by a screw and the other pad is pushed by the piston. Often, the pads are installed with some high-temp anti-squeal silicone on the non-rotor side.
  • ThatGPzGuy
  • Away
31 Jan 2008 18:01
#192100
Thanks for the diagram.
They are not held on by anything. They just fell out a minute ago when I was working on it. The caliper separated into the two pieces you see the pads came out. Not sure how it all goes back together just yet. Still working on it. They were pretty grungy though... full of dirt and oil.
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
  • ThatGPzGuy
  • Away
11 Feb 2008 13:59
#194021
Update:
Got the forks fixed and some electrical issues figurd out. Thanks everyone. I cleaned the heck out of the brake pads and put them back in but now my brakes are spongy and one of the pads leaves black grease-like marks on the rotor. I am thinking there are pads and maybe a caliper rebuild in my future? I am missing the spring pad for the caliper (#92081) as well. Also, the front brake lever does not retract all the way. So, when you brake the lever does not go back and shut off the brake light. It's like the MC is a little stuck or? Looks like I might be rebuilding the master cylinder too. I guess I should plan on doing them all at once, yeah? Is there anything I need to know about rebuilding these two?
Other than being loud and having lousy brakes it runs like a champ! All my cold-starting issues appear to be resolved and the forks no longer leak. I took it out yesterday for my first long ride and except for the cold and some rookie nervousness (missed shifts, blinkers staying on, starting out in 3rd gear, etc) it went well.
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
  • KZ_Rage
  • KZ_Rage's Avatar
  • Kentucky Bourbon Barrel Ale
11 Feb 2008 14:29
#194028
ThatGPzGuy wrote:
Update:
Master rebuilds can be a pain! Be sure to check the bore inside the master for rust/pitting. Not much you can do if it is except try to find a better one on fleabay.
Get a set of pads from Jeff at Z1, it just isn't worth the effort to reuse old pads. If it feels spongy now and didn't before you might have a leak at the piston or you kinked the old hose and it is now exhibiting an aneurysm do to age and breakdown at the kink. Try bleeding the system completely. A complete change out of the brake fluid is a good idea every year or two anyway.
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
2006 ZG1000A6F (Totaled)
2001 ZRX1200R (Sold)
  • Link14
  • Link14's Avatar
11 Feb 2008 19:06
#194095
I'd recommend getting some speedbleeders too. They make bleeding brakes a whole lot easier!
  • ThatGPzGuy
  • Away
12 Feb 2008 17:08
#194284
Yeah, I was going to give Z1 a call.
As for the MC rebuild it is probably due after 27 yrs. I have seen the MC rebuild kit on Z1 but not the caliper kit? I guess I can source the individual parts from the stealer dealer.
Link 14, love the speedbleaders. I have them in all my cars. For the bike I figured I would use the vacuum pump. That is the only thing that has ever worked on my dirtbikes.
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
