KZ400 project - rear wheel/sprocket/chain
  • primemover
  • primemover's Avatar Topic Author
21 Jan 2006 06:42
#19034
Hi All...
working on a KZ400 (1978) project bike....
i'm ready to start doing some back end work....
my plan is to take off rear wheel and do a couple of things:
- clean up rim
- replace sprocket
- replace tire
- check alignment
- etc...
curious....
i need a new sprocket (current one is really worn)
i've heard that it is best to replace rear/front sprocket and chain at the same time...
advice?
comments?
i found a couple of KZ400 rear sprockets on e-bay, but not sure if that is the best way to go (prob not)...
thanks...
- prime
  • ejshotgun
  • ejshotgun's Avatar
Re: KZ400 project - rear wheel/sprocket/chain
21 Jan 2006 07:43
#19053
It's best to change all at once (front/rear/chain) and you'll probably want to upgrade to the 530. Go to Z1Enterprises and they will probably have what you need. And if you have questions don't hesitate to call they are great with customer care.
I'd just get new chain and wouldn't chance a used one.
Eric
  • Biquetoast
  • Biquetoast's Avatar
  • King Jeremy The Wicked
21 Jan 2006 09:27
#19072
ejshotgun wrote:
It's best to change all at once (front/rear/chain)...
I agree. Doing otherwise is imprudent and a waste of money...
(1.) '75/'76 KZ400D - Commuter
(4.) '75 KZ400D - Sold
kz750twins.com
  • primemover
21 Jan 2006 09:44
#19076
thanks guys....
will do....
- prime
  • DasTeufel
  • DasTeufel's Avatar
21 Jan 2006 13:25
#19118
Prime, since you will already have the wheel off, take the time to check your bearings and brake shoes too (pads if applicable), a little bit goes a long way!
2009 KTM 690 SMC
2008 Kawasaki Ninja 250R
2001 Suzuki GSXR 750
Wildomar, CA
  • primemover
21 Jan 2006 14:07
#19122
thanks for the tip....
will do!
- prime
