Shock angle
- minutiesabotage
Shock angle
20 Jan 2008 08:29
Does anyone know if there is a good reason Kawasaki did not angle the rear shocks vertical. My understanding of the geometry is that vertical is the most effective position.
I ask because when I put my new swingarm on, I am going to have to have someone make mounting points for the shock (I do not trust my welding skills to something that important), so I can pick whatever angle I want.
Ignore spring rates and shock length, I am going to have to get new shocks anyway.
- StreetfighterKz
Re: Shock angle
20 Jan 2008 08:53
Vertical is the most effective only when the shock and swingarm are perpendicular to each other. As the swingarm moves upward, depending on howmuch travel you have, the shock can go past vertical and become less effective.
So designers placed the shock at an angle so as the swingarm moved through its arc and compressed the shock the shock moves more toward vertical and acts like it has a more progressive rate for a constant spring rate.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- PLUMMEN
Re: Shock angle
20 Jan 2008 10:35
StreetfighterKz wrote:
what he said!Vertical is the most effective only when the shock and swingarm are perpendicular to each other. As the swingarm moves upward, depending on howmuch travel you have, the shock can go past vertical and become less effective.
Later, Doug
- minutiesabotage
