95 zx9r fork swap stem ?
- gpznutt
19 Jan 2008 23:03
Just wonderin if anyone knows someone who sells or has the specks to machine a stem for a 1982 gpz750 , zx9 usd fork swap
- StreetfighterKz
Re: 95 zx9r fork swap stem ?
20 Jan 2008 09:03
Possible Kosman but that's the only place that might have a clue. Most people doing swaps figure it out as they go by comparing each stem and taking measurements.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- steell
20 Jan 2008 13:12
Simple job for any machine shop, the whole thing can be done on a lathe.
Is the Zx9 stem the same length as the 750? can you just do a bearing swap and use the ZX9 stem? I did a bearing swap to put a 99 GSX750 front end on a KZ750E, had to lengthen the stem though.
Post edited by: steell, at: 2008/01/20 16:17
- gpznutt
20 Jan 2008 19:20
the stems are far apart in dimensions its just that i work 24/7 lookin for a simpler way but will have my bro send it too Raceworks , Mike does exelent work.
thanks guys
thanks guys
