Help! Brake Caliper Problem 1981 kz650h1
  • jeffo
  • jeffo's Avatar Topic Author
19 Jan 2008 18:37
#190144
I tried to take the easy way out and put one of those bleeders that makes it easier to bleed the breaks . . .the problem is I broke the damn thing off :ohmy: :ohmy: Then the extractor bit broke off creating a perfect plug.
Now I cannot get a drill bit to drill a hole out and I used a drenel tool to try and rough up the surface for the drill bit but I just cannot drill a hole through.
So I need to either find out how to get the broken off bleeder out or get a new caliper maybe a modern one??
Thanks for any help you can give me :)
1981 KZ650H1 CSR
Re: Help! Brake Caliper Problem 1981 kz650h1
19 Jan 2008 19:30
#190147
If there's a local machine shop, might take it in for an estimate, as they have sophisticated tools for more precision work (bits, presses, etc.), before deciding to purchase a replacement.
Good Luck! :)
  • SPARKY47
  • SPARKY47's Avatar
  • 1980 KZ500 B2
19 Jan 2008 19:38
#190149
or you could dissolve it out with nitric acid.
1980 KZ500 B2
  • jeffo
20 Jan 2008 10:13
#190234
I found this in case I cannot get it out . . .I think its a match? The part number is a little different but all the parts that go into it were the same and it had the same design and I figured it would work with my current mounting arm.
I am still going to try and get it out today if I can but I am not going to stress to much unless the replacement does not work.
tiny.cc/2nhwy
Post edited by: jeffo, at: 2008/01/20 13:13
1981 KZ650H1 CSR
