kz650 throttle cables?
  • Skydivelife
  • Skydivelife's Avatar Topic Author
19 Jan 2008 07:39
#190070
Hey guys,
one of my throttle cables snapped in my bike and a buddy of mine kind of answered my question but I feel he might not know what he's talking about. the cable that snapped is the one that makes the bike accelerate. Is that the push or pull cable?
Also, are the push and pull cables any different from each other? or are they interchangeable.
and finally, I have a 1978 kz650 H. can I get a throttle cable for a kz650 B, or A, or other model and still be ok? I don't understand the difference in the letters.
thanks!
Nate
  • JMKZHI
  • JMKZHI's Avatar
Re: .
19 Jan 2008 08:28 - 03 Dec 2008 20:29
#190074
del
Last edit: 03 Dec 2008 20:29 by JMKZHI.
Re: kz650 throttle cables?
19 Jan 2008 09:16
#190084
Skydivelife wrote:
... Is that the push or pull cable? Nate
Hello Nate, and Welcome to the site. We're glad you're here! :cheer:
All braided cables are PULL (think rope). The only push cable I know about is the solid inner wire style cable used on some lawn mower throttles (for example) where the same cable pushes and pulls without benefit of a return spring system. :)
  • The Gringo
  • The Gringo's Avatar
  • ¡Usted no necesita otra motocicleta!
19 Jan 2008 09:18
#190085
If you have a 1978 it has to be either a B (std.) a C (Custom) or possibly a D (SR). These should share a common cable. The H models (650 CSR) were not produced until 81 and because of the mini ape handlebars they have longer cables. If your cable that broke is an oem cable it should have a number printed on the outside of the cable ex. 12-140 is the pull cable from a 650 C and would translate into part # 54012-140.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
19 Jan 2008 09:36
#190088
  • RonKZ650
  • RonKZ650's Avatar
19 Jan 2008 10:12
#190089
And in case it wasn't explained it is the "pull" cable you want. The 2 cables "push" and "pull" are not the same cable, although many people dispute this. The difference is in the chrome elbows on the cables up by your throttle grip. Look at how they are mounted, you'll see that the length and shaping of this elbow is different between the two cables. It has to be this way because of the close spacing between the cables to twist them into the throttle housing one would butt against the other if they were the same, so you'd fully screw in the first cable, then go to fully screw in the second only to find out you can't because the first one is in the way. You could probably use the same cable, but one would be scewed all the way in and the other only a few threads until it butted against the first. Look at your steering stem for serial number as patton said, the letter after the KZ650 determines what model you have. B, C or D in 1978
  • Skydivelife
19 Jan 2008 10:36
#190094
thanks guys!
the reason I thought is was an H is because it says that on my insurance? looks like I have to get something fixed or checked out. but thanks for all your advice!
-Nate
19 Jan 2008 14:22
#190115
As explained above, both cables are "pull" cables. They each pull on the throttle cable pulley which in turn operates the carb throttle valves (slides); one cable pulls them open and one pulls them shut. Sounds like you need the throttle opening cable, but I would replace both (they are different) while you have things pulled apart. Also, I would check to ensure they are routed correctly and not binding. That may have caused your cable to fail as the Kawasaki cables last nearly forever if lubed annually. Ed.
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
20 Jan 2008 06:06
#190191
The H model designation on your Insurance papers should be fine.
The Insurance Co's listings for the KZ650 often go back only 25 years, giving them an H model to relate to, and use the longer VIN #s sometimes as well.
Mine is like that as well.
Welcome. Throw up some pix of your ride/s as well, and put your bike info and your location in your signature. It helps when trying to answer your questions.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
