Front frame mounted side reflectors
  • SebRain77
  • SebRain77's Avatar Topic Author
  • When in doubt, gas it!
18 Jan 2008 17:42
#190003
wondering if anybody would have or would know where to get the front frame mounted side reflectors (part# 28012-016 i beleive) for a 77 kz650.
all comments are welcomed!
Ever hit the pavement? I did, put that gear on!
1977 KZ 650C1 - First bike, ever! For sale - or not!?!?
2004 Z750 - More power than I'll ever need...
Gatineau, Qc, Canada eh!
  • The Milkman
  • The Milkman's Avatar
Re: Front frame mounted side reflectors
18 Jan 2008 17:49
#190008
Are you looking for original ones or would a little smaller aftermarket ones work?
Ride safe
  • Bluemeanie
  • Bluemeanie's Avatar
18 Jan 2008 17:52
#190009
Boy that's gonna be a tough one SebRain77, I still have mine (no, not for sale... lol) I've only seen them on ebay once or twice in last couple years. Z1 does not carry them, so good luck.
  • SebRain77
18 Jan 2008 17:54
#190011
aftermarket would work, as long as i have some when i go to the dmv to get it inspected.
18 Jan 2008 18:46
#190019
No problem. www.kawasaki.com says the part is still active, which normally means it's available. The part number for the reflector is indeed 28012-016 (REFLECTOR,REFLEX). Behind each reflector there is a rubber damper part #92094-011 (DAMPER RUBBER,REFLECT).
Plug in the part numbers at:
www.ronayers.com/browseparts.cfm
The reflectors are $10.18 ea. and the dampers are $1.49 ea.
Be sure to check the part numbers in case I mixed something up.
Post edited by: 650ed, at: 2008/01/18 21:47
  • SebRain77
19 Jan 2008 06:05
#190045
Thanks Ed! That was easy enough! It helps when people know what you are talking about! Not like that wannabe Kawasaki dealer near my place! ouch!:laugh:
  • 76 LTD
  • 76 LTD's Avatar
19 Jan 2008 07:06
#190056
Not familiar with 650s but if they are same as 900/1000 i have some usable ones i would let ya have for the cost of mailing them
  • SebRain77
19 Jan 2008 07:25
#190063
76LTD, I guess that would work.:)
  • Bluemeanie
19 Jan 2008 07:32
#190067
They are not required here and I hardley ever ride at night. I almost took them off years ago (dorky looking) but they keep the bike that much more original! ;)
