ZX6R(636) Steering Stem to KZ900
  • Old Man Rock
  • Old Man Rock's Avatar Topic Author
16 Jan 2008 04:23
#189526
Hey all,
With the rear ZX6RR swing arm swap complete, now onto the front end.
Thanks to all regarding previous postings on how to remove the KZ steering stem... Grind the weld ~ 1/4" and tap it out. Didn't require a press! B)
ZX lower tree issues: The KZ steering stem is 26mm and the tree opening is 38mm. The ZX stem seems to be high grade aircraft aluminum, I think it is at least.
Questions:
1) Do I have the ZX Billet stem milled to the KZ stem dimensions and threading or will I loose some of it's strength in doing so?
2) Is it better to have a whole new hardened steel KZ stem fabricated with the base being wider 38mm for pressing into the ZX lower tree?
NOTE: 1/2" longer due to grind & tripple tree base thickness.
3) Is it safe to just have a 36mm tree plug w/26mm hole fabricated? (Press and weld bottom end to plug)
Obviously some of these choices = higher costs $$$.
Ideas that others have done & if someone can provide somewhat of an idea of what I can expect in $$$ in having a stem fabricated would be awesome.
Thanks,
Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • steell
  • steell's Avatar
Re: ZX6R(636) Steering Stem to KZ900
16 Jan 2008 06:54
#189544
You don't want to machine the aluminum stem, it will weaken it.
You don't need, and don't want a hardened steel stem, hardening only strengthens the steels wearability, and stems don't wear, hardening also makes the steel more brittle, and you most certainly don't want that.
If you have a lathe you can turn a new stem out of mild steel to the dimensions you require, if not then a machine shop can make you one.
That would work also.
