Re-gearing for the KZ750
  • cafekz750
  • cafekz750's Avatar Topic Author
15 Jan 2008 10:23
#189425
I have an '81 KZ750-4 and for the next season I was thinking about changing the sprockets with acceleration in mind.
Anyone have good luck with this?
I have the 630 chain with the stock sprocket up front and I was thinking about toying with adding teeth to the rear sprocket to see what I like.
Anyone have a used 630 sprocket with 33, 35, 38+ teeth?
Chain is not a problem.
My plan is to find what I like and then look to the 530 conversion once I need to replace the whole lot.
Thanks.
1981 KZ750H2 - V&H 4-1 pipe, pods, jetted, clubmans, homebrew rearsets, 18" rear wheel and more.
Parting out a 1982 KZ750H3 to fund future projects
2 other non-Kawasaki motorcycles
  • jagrider
  • jagrider's Avatar
Re: Re-gearing for the KZ750
15 Jan 2008 11:17
#189437
I have 77 kz1000 16/40 gearing now, but I'm using a 19/40 with 525 change I just had the sprockets made.Look up jagrider in kzrider you can see it in the pics. Went with 19 front to keep my RPM downs for long miles. But have these as extrs gears 14 and 16 for drag racing the bike.
Gear ratio charts to play with.
kzrider.com/component/option,com_joomlab...w/catid,5/id,189788/
Here is a company that make some very strong chains and sprockets to. Talk to Mike
They can make what ever gear you are looking for.
sidewindersprockets.com/titanium_chain.html
rebel gears make sprockets to pricing good talk to
Doug tell him James sent you.
www.rebelgears.com/
Post edited by: jagrider, at: 2008/01/15 16:25
Post edited by: jagrider, at: 2008/01/18 07:14
Loud pipes save lives.
  • Bluemeanie
  • Bluemeanie's Avatar
16 Jan 2008 20:24
#189658
My 650 uses a 16/42 and I swapped for a 15/42. Noticably harder acceleration, 2nd gear comes up real fast! RPM's went up about 500 at 70mph.
