Nice to play with-Gear ratio chart
  • jagrider
  • jagrider's Avatar Topic Author
15 Jan 2008 06:39
#189387
Guys here is Gear ratio chart site you can look up,log in all tire rim size,trany gearing, front and rear sprockets. And it will give RPM and speed in gears.
If your changing your front are rear sprockets
www.garveynetworks.co.uk/gear/index.php
This site is for spark plugs,give you a understanding of heat ranges and if you type in NKG - these numbers B7ES, B8ES, B9ES, witch ever model you use it will give all brands that match the model number you put in.
www.sparkplugs.com/default.asp
Performance is all about TORQUE good to no info.
www.msgroup.org/forums/mtt/topic.asp?TOPIC_ID=4634
jagrider
Post edited by: jagrider, at: 2008/01/15 10:47
Loud pipes save lives.
  • OKC_Kent
  • OKC_Kent's Avatar
Re: Nice to play with-Gear ratio chart
15 Jan 2008 14:05
#189450
Hi jagrider,
Hope you don't mind if I jump in here and post a gear ratio chart I found on the internet. Might as well keep this stuff together.
www.cunnington1.freeserve.co.uk/gearing_v12.xls
Cashion, OK
78 KZ650 B2 85,000+ miles
  • jagrider
15 Jan 2008 14:41
#189454
Cool good stuff, man this best site I found for kz info - kzrider is the best.
  • Aric
  • Aric's Avatar
15 Jan 2008 17:17
#189484
Here is another i like to play with from time to time.
www.gearingcommander.com/
  • jagrider
17 Jan 2008 14:14
#189788
Another gear chart...
www.vmar.com/java/gear.html
jagrider
