Z1 Front brakes
- Dice
Z1 Front brakes
14 Jan 2008 08:32
After being a lurker for a few months I finally have a question for the masses. I am armpit deep into resurecting a 75 z1 which has not seen the pavement for almost 20 years.
I am at a crossroads on what to do about the front braking system. Do I rebuild the stock system or look aftermarket? The only salvageable part on the bike now is the master cylinder.
I am considering looking to the aftermarket, but am having a difficult time finding anything that fits the z1. Does anyone make rotor and calipers that fit this bike?
1975 Z1B
- PLUMMEN
Re: Z1 Front brakes
14 Jan 2008 08:43
id say youre gonna have a hard time finding parts other than z1 or some of the early triple stuff that will fit the 6 bolt z1 hub.check into a 76-78 900/1000 or 650 they used a 4 bolt hub that is really easy to find rotors for;)
- Mcdroid
- Gone Kwackers
Re: Z1 Front brakes
14 Jan 2008 12:43
Plummen is right, anything aftermarket for a Z1 might be very expensive...become one with the eBay gods...it is usually overflowing with Z1 parts
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- Kawickrice
Re: Z1 Front brakes
14 Jan 2008 13:34
I just went through the same thing with a 73 Z1. I used a 77 kz650 master cylinder and paid through the nose for a z1 caliper on e-bay. While I was waiting for the z1 parts i put kz1000 fork tubes on so i could ride. The kz fork tubes will accept a broad range of calipers due to bolt spacing being wider.
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- Dice
Re: Z1 Front brakes
14 Jan 2008 16:50
Yeah I am really not wanting to switch over to a kz front end after I have just rebuilt the front end on the z1 a few weeks ago!
I see that z power in the UK has what I am looking for, but its a little pricy. I didn't know if maybe Grimeca had something, or if someone has fabricated a custom mount for a more modern caliper/disc on a z1 front end.
Maybe I will just keep watching ebay for another caliper and hope I can get one before it warms up enough to actually ride it.
1975 Z1B
- Dice
Re: Z1 Front brakes
14 Jan 2008 16:52
Sorry double post:blush:
Post edited by: Dice, at: 2008/01/14 19:54
1975 Z1B
- BohicaBob
Re: Z1 Front brakes
14 Jan 2008 17:50
What I did with my '73 Z1's front end: replaced the fork lowers with those from a KZ650 (you could use those from '77-'78 KZ1000 as well), used damper rods from a '76 KZ900 (for better damping than the Z1s), Progressive springs, Telefix fork brace, '79-'80 KZ1000 calipers (which are much better than the Z1 dual disc setup), DP brake pads, and '79-'80 KZ1000 front disc rotors (4.5 mm thick).
