1978 kz 650 damper removal?? fork seal replacement
- odl666
10 Jan 2008 15:57
Cant seem to get the allen bolt to come loose at the bottom of the forks, have tried an impact, i also looked in the manual and said a special tool was neede wondering if there is another way of taking that dnm allen bolt off. Thanks
1978 kz 650b with gpz faq mods cams carbs polished and ported
1979 gs750e
1972 bsa lightning under construction
1979 gs750e
- RonKZ650
Re: 1978 kz 650 damper removal?? fork seal replacement
10 Jan 2008 18:18
You really need an decent impact tool to do the job. Also leave the forks assembled until the allen comes loose. Spring pressure from the fork spring will aid you.
Post edited by: RonKZ650, at: 2008/01/10 21:20
- OKC_Kent
10 Jan 2008 20:29
Use an air impact wrench...not the hit-it-with-a-hammer kind.
Cashion, OK
78 KZ650 B2 85,000+ miles
- odl666
11 Jan 2008 07:22
thnks iwas using the air impact and i also had taken the springs out first. thanks for the advice
1979 gs750e
1979 gs750e
