Overheating front brake
  • grandadbob
  • grandadbob's Avatar Topic Author
07 Jan 2008 10:50
#188140
I have an ongoing front brake problem. The brake fluid heats and expands forcing the pads to bind to the disc. The bike slows to a halt. I have to release the fluid pressure by cracking open the bleed nipple on the caliper.
I have renewed the master cylinder and caliper piston seals. The caliper appears to slide on the small caliper shafts but there does seem to be some play in one of the shafts.
My next move will be to replace the brake hose but I can't see that curing the problem.
Does anyone have any ideas?
'83 KZ550 C4 LTD
'06 VFR800 Vtec
  • BSKZ650
  • BSKZ650's Avatar
Re: Overheating front brake
07 Jan 2008 11:57
#188148
the hose can be collapsed (sp) had that happen on a race car once, on that one we rebuilt everything and after a short run the right front was grabbing, it would lock the wheel up in the pits, so yes it may be the hose on the inside that is giving you the problem
77 ltd1000, current rider
76 kz900, just waiting
  • StreetfighterKz
  • StreetfighterKz's Avatar
07 Jan 2008 12:01
#188149
After rebuilding your caliper and master cylinder did you use fresh fluid from a sealed container? It sounds like you have water in your system that heats up and begins to expand.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • trippivot
  • trippivot's Avatar
08 Jan 2008 08:13
#188258
check the master cylinder pressure return/release orifice. it is a tiny passage inside the master cylinder and needs to be clear. what you look for is the fountain squirt out of the reservoir when the brake lever is squeezed then released.
the other option I can think of is that the brake caliper piston is sticking inside the caliper bore and not relaxing after pressure is released.
the last thing is if the brake lever has a threaded bolt as a adjuster to the plunger and the adjustment is too tight.
good luck
  • grandadbob
08 Jan 2008 12:31
#188285
I can only find one drilling between the reservoir and the master cylinder. There is what looks like a drilling but appears to be a casting spot with muck in it. Could this be the return orifice?
There is no adjuster between the lever and the piston.
I renewed the caliper seal recently and the piston seemed free.
'83 KZ550 C4 LTD
'06 VFR800 Vtec
  • KZQ
  • KZQ's Avatar
  • Away
  • Administrator
  • Administrator
09 Jan 2008 06:01
#188378
"appears to be a casting spot with muck in it."
Yep! If that bleed is blocked off the system can't take fluid back from the caliper.
kzcsi
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
